96 Camry Oil Pump Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2010, 07:58 PM   #1 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
So Oil pump pulley broke as you can see, I'm trying to find a replacement but all the places I've looked sell the entire oil pump for a little under a hundred
Anyone know a place that I can find just the pulley itself? I've attached photos for reference.
iovaykind is offline   Reply With Quote
Old 05-22-2010, 08:20 PM   #2 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
Did you try the junkyard? Looks like rockauto sells the pump with it.
EDIT: The part number is 13524-74020 at least for my 95 camry. Its listed as $30. Toyotapartszone.com sells it for $20. Hope this helps.
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 05-22-2010, 10:29 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
You'd be crazy not to replace the whole unit, because it broke who knows what else is wrong with the pump. Did you pull it apart to inspect the pump housing?
You can buy the whole assembly for about $65.
71Corolla is online now   Reply With Quote
Old 05-22-2010, 10:41 PM   #4 (permalink)
iovaykind's Avatar
Could only find the oil pump for $100, where did you find it for $65?
Old 05-22-2010, 11:05 PM   #5 (permalink)
71Corolla's Avatar
I saw them on Ebay a couple of months ago for about that price. It comes with the whole lower cover assembly not just the oil pump, but you can just unbolt it and only install the pump.
Even if you did spend $100 on the unit, it's worth it unless you are absolutely sure the sprocket just broke on it's own and not because the pump seized etc.
Old 05-22-2010, 11:29 PM   #6 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
How the eff does that happen? Ive never seen anything like it.
Does the shaft rotate?
carsrus is offline   Reply With Quote
Old 05-23-2010, 08:29 AM   #7 (permalink)
iovaykind's Avatar
It had been making noises and I drove back to my house with all the equipment so I could diagnose the problem. The oil light had been on the whole time. The engine died and it literally gave out right before I turned into my driveway. I thank God it didn't happen on the highway or something.
Pretty sure it's just the pulley but it still rotated that's why it was making noises. Thank bdy0003 for the part number.
Old 05-23-2010, 08:39 AM   #8 (permalink)
Start looking for a new engine/car. NEVER drive with the oil light on. The engines toast since the oil light comes on at some joke pressure like 7 psi.
Old 05-23-2010, 07:58 PM   #9 (permalink)
iovaykind's Avatar
My dad and I tested the engine and it still works, the engine's not toasted. We just need to fix the oil pump and while we're at it we're going to replace the water pump, and some gaskets as well.
