sounds like the clutch is not fully disengadging/ returning.
My guess would be that one or more of the pressure plate springs/fins has failed. what leads me to believe this is the clutch pedal not returning all the way......
Pushing on the clutch pedal pushes on the pressure plate springs which releases pressure on the clutch disk. When you let off the clutch the springs push back on the throw out bearing, which pushes on the clutch fork, which pushes the salve cylinder back in, which cause the clutch pedal to return.
Also what EEngineer said is more likely the case.
Hope that's not to confusing lol
Reason: Adding to
