The car has a history of overheating and blown
head gaskets
; both before and after an engine rebuild several years ago. The engine was rebuilt due to an oil sludge problem. With the latest overheat and probable blown head, I am about to throw in the towel unless I can gain some confidence as to what is causing the overheating in the first place.
While overheating due to a blocked catalytic converter is not a common topic in this forum, it is frequently discussed topic on the internet. If I knew that one or both converters were bad I'd repair the car; otherwise we're looking at a donation to the junkyard.
The overheating is not due to low fluid levels and tends to occur without warning after coming to a stop or near stop (fans and radiator are okay). I recently felt the car was losing power so I changed plugs, rotor, cap, and wires. The car was definitely peppier and was driven 300 miles cross country with no problem but a week later she blows.
1995 Camry 5SFE 2.2L 155K
