synthetic or not?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2010, 01:33 PM   #1 (permalink)
.xShAgUaRx.'s Avatar
View .xShAgUaRx.'s Photo Gallery
synthetic or not??
My car has about 204k. Ive been wondering if i am able to go with a full synthetic or synthetic blend or am i better off going with a good conventional oil? i currently have some quaker state with slick 50 for my next oil change im gonna do in the next day or two.
1993 Toyota Camry SE v6 5spd
1980 Pontiac Formula Firebird
2003 Chevrolet Silverado 1500 Z71
.xShAgUaRx. is offline   Reply With Quote
Old 05-24-2010, 02:08 PM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
IF you switch to synth at this point, you could start noticing some leaks (I think). I would stick with the dino.
Why do you want to switch?
Chris Crash is online now   Reply With Quote
Old 05-24-2010, 02:20 PM   #3 (permalink)
if my engine was new enough royal purple. but i wont consider that at my milage. semething like castrol synthetic blend. i have a good conventional picked out. for conventional ill use quakerstate.
Old 05-24-2010, 02:46 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Have you been under the valve cover recently (best way to check for sludge)? Generally, I wouldn't switch to synth on an old engine unless you're having sludging problems, and even then might just switch to a quality high-detergent dino (such as Castrol GTX) with shorter oil change intervals.
Personally, I switched to running synth on mine (I tend to slop my OCIs, and my '95 5S-FE tends to sludge dino), but I'm also having to replace drippy oil seals as I get around to them....
Old 05-24-2010, 04:22 PM   #5 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
I would stick with conventional, there arent any benefits to running synthetic in an older engine.
It will most likely just start leaking and burning oil faster.
carsrus is offline   Reply With Quote
Old 05-24-2010, 06:24 PM   #6 (permalink)
View larocque44's Photo Gallery
Im running 10w30 castrol syntec have been for the past 2 months havent noticed any leaks had 213,000 now at 215,000 and running great should help with cold winter starts as well.
larocque44 is offline   Reply With Quote
Old 05-24-2010, 06:34 PM   #7 (permalink)
2win2rbo's Avatar
Gameroom cash: $156522
View 2win2rbo's Photo Gallery
As above, if you're having sludge problems, synthetic would do good. That is if you're seals have already been replaced.
1993 Toyota Cresta Tourer S JZX90
1988 Toyota Mark II GX71
1999 Subaru Outback 5-speed
2000 Toyota Mark II IR-V
2003 Subaru Legacy BP5 2.0R
2win2rbo is offline   Reply With Quote
Old 05-24-2010, 10:00 PM   #8 (permalink)
View sc2dave's Photo Gallery
this stuff is garbage.This company has gotten sued for all the misleading claims.
sc2dave is offline   Reply With Quote
Old 05-25-2010, 12:29 AM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
IMO a good conventional oil and a shorter oil change interval would be better. However, if you want to try a blend check out the Motorcraft oils at WalMart. Autozone also has Castrol blends with a Bosch filter on sale. Again, I'd still go with a shorter interval instead of trying to lengthen it.
Old 05-25-2010, 01:43 AM   #10 (permalink)
as far as i know i dont have a real big sludge problem. usually i try to change my oil every 3000 miles since i do alot of city driving.
