93 camry need help
i have a gen 3 93 camry 6cyl i think it has an overheating problem even though the temp gauge is showing normal. while on a long 5 hour drive to sudbury ontario with 3 half hour stops on the way the car would hesitate and even drop out of gear. When i pull over to check the engine it is extremly hot. it also dosnt like to start smoothly in cold weather (ie) i need to hold my foot on the gas for a few minutes befor it willl idle by its self. iv sprayed carb cleaner into the intake to clean it out abit iv also removed the aic and cleaned that so now it runs abit better but still dos the same thing. Unfortunitly now im stuck and have no idea what to do.
-1990 Corolla SR5 Modified, body work done and currently being painted ( Girlfriends car)
-1993 Camry LE Stock with sound system Currently in the process of painting( Moms car)
-1991 Corolla LS Stock with sound system and Audi rims( Dads car)
-1989 Corolla GT-S Modified( My Car)
