Replace third brake bulb - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2010, 12:51 PM   #1 (permalink)
View tmaniac's Photo Gallery
USA Replace third brake bulb
I got 92 Camry which works great, 120k mil. I am trying to replace a burned out brake light bulb, the third one. But I can't open the cover, tried to use hooks from both side at same time, tried to lift up and tried to pull back. None of these tricks worked, I am afraid to use too much force that breaks the cover. Any help is appreciated.
tmaniac is offline   Reply With Quote
Old 05-25-2010, 12:56 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
hmm i did it once like 2 years ago, but i don't remember it well... i think you have to squeeze the sides of 3rd brake light cover and lift it up at same time or something. took me a while to figure it out too.
then it will be straight forward (you will see the burned out bulb).
good luck!
Old 05-25-2010, 02:27 PM   #3 (permalink)
Thank you very much, I will give it a try. That's the only thing I did not do, squeeze to center then lift.
Old 05-25-2010, 03:37 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
The instructions are in the owners manual.
'07 Honda Ruckus Big Bore
Old 05-25-2010, 04:52 PM   #5 (permalink)
Gameroom cash: $303755
When I had to replace that bulb in my 94, I found the best way to do it was to crawl in the trunk and loosen the tabs that hold the assembly in place from underneath. I too was fearful of breaking it, so I did it this way. 30 seconds and it was loose. After changing out the bulb I put it back in from up top.
Mike
Old 05-25-2010, 07:32 PM   #6 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
Firmly squeeze the sides and pull it up toward your chin!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
The Following User Says Thank You to eyeball96 For This Useful Post:
gvw (03-06-2012)
