Hi All
98 Camry 2.2l 5fse engine
My daughter was driving and broke down with a major coolant leak and
car will not start. Figured out probably a water pump failure/seizure. Started timing belt replacement and ran into the following problem. Have the top timing cover off and the belt is still on. When I turn the crankshaft to line it up to 0 the camshaft is not turning. Crankshaft turns but belt doesn't move! How do I get the camshaft and crankshaft lined up? When I take the belt off, can I turn them separately to line them up?
I have the crankshaft bolt off (used the starter bump method mentioned in these forums, worked like a charm) and will remove the pulley tomorrow along with replacing the water pump.
Also, I have the car up on stands and in park. Went to put it in neutral but shifter won't move and the front wheels move freely when in park. Does the car have to be in neutral for the
timing belt
change? Do I have other major problems besides the timing belt?
Thanks in advance for any help.
