Towbar / toe bar??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2010, 09:33 PM   #1 (permalink)
tekno9000's Avatar
View tekno9000's Photo Gallery
Question Towbar / toe bar???
Changed tires and got alignment done. While aligning the operator told me that my toebar / tow bar was bent? It was in rear wheel.
Can some one please explain what it is? And what should be done with it.
Thanks.
Thanks,
Tekno 9000
1995 Camry LE 5SFE 4 Cyl.
tekno9000 is offline   Reply With Quote
Old 05-29-2010, 10:39 PM   #2 (permalink)
View 500KCamry's Photo Gallery
Thanks.
I think he means the rear suspension rod that goes from the wheel to the center of the body. There are two fixed rods (towards the front) and two adjustable rods (towards the rear), one set for each wheel. The rearward rod is adjustable in length so you can change the toe angle of the rear wheels. If the rod was bent it would explain why your rear alignment was out. Maybe they were still able to adjust the bent rod and complete your alignment.
When the rear end is out of alignment the car can be a handful to handle. If the rear tires are on different types of road surfaces, the one with the most traction tends to steer the car, and you can notice it. The rear of the car will seem to jump. The car will also dog track on the road, drive somewhat sideways to one side or the other. When this is the case you will notice the steering wheel being off center to keep the car driving straignt down the road.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
