Ok, so first thing today, I was able to remove two of the three nuts holding the flex pipe to the exhaust manifold. The third one was damaged while trying to use an impact gun the day before. I removed a couple of brackets to provide more of a clearance, and my dad was able to saw the nut enough to weaken it for removal... without damaging the stud bolt. After that, the pipe separated easily.
However, that wasn't enough! There was still a bracket that the pan was getting hooked on. I had to remove that, and upon re-installation, I had to remove another bracket to get one of the 17 bolts back in.
Quite a pain the butt I've gotta say, just to remove the friggin' pan.
Oh well, it's done.
Also, I hope some silicone getting into the pan won't be a big deal. My dad was pretty liberal with the RTV... maybe it will drain out after the next oil change?
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
