could this be the alternator? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2010, 01:07 AM   #1 (permalink)
THEARCHITEK's Avatar
View THEARCHITEK's Photo Gallery
well everytime i have the volume too loud on my car like the bass from the subs hits the lights dim and i change the battery and it does it but less but is like the battery runs out and my amp shut off ... it has been doing this every scince i put the system and ive tried diffrent amps and it does the same thing but the alternator charge fine the battery but does this means my alternator is going bad??
by the way i have a 4gauge cables and a capacitor
1100w kenwood amp 2 chl
two 12'' pioneer 1000w each
THEARCHITEK is offline   Reply With Quote
Old 05-31-2010, 01:14 AM   #2 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
when yr amp shuts off, it doesn't mean yr running out of battery- it just means that yr pushing the amplifiers to overheat.. with those size of subs and power rating, you're better off with a 1500w mono-block class D amplifier, bridge wire the subs to bring the ohm rating down to .5/0 ohm. Do the big 3 upgrade too if yr serious about yr car audio.
best of luck.
btw..
Originally Posted by THEARCHITEK View Post
well everytime i have the volume too loud on my car...
.. or you could turn it down then would be sooo much cheaper!
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 05-31-2010, 01:22 AM   #3 (permalink)
oh but ive tried 3 diffrent amps and dey all have done the same thing and btw my subs are not bridge because if i do it would b worst and start blowing up my fuses like it has before had blown me 3 of the, 100 fuses
Old 05-31-2010, 06:17 AM   #4 (permalink)
View CDJr's Photo Gallery
It doesnt mean your alternator is going bad, it means its not powerful enough. That 70 or 80 amp stock alternator is basically strong enough to produce enough power for the accessories in your car...it simply cant put out enough for the car and an 1100 watt amp too so its trying to run off the battery. You can replace batteries but all its going to do is drain them. What you need is a higher output alternator, one that can supply the car and the amp and still charge the battery. Id suggest at least a 130-150 amp cuz trying to run it off too small of a power supply will just waste batteries and eventually trash your amp. Hope this helps....
CDJr is offline   Reply With Quote
Old 05-31-2010, 08:46 AM   #5 (permalink)
well i have the stock 70 an the higher i could find is 80 could this 1 help ? wow then this alternator is weak bcauz the civic that my bro has it does not do that and he got four 12'' 1000w subs and 2 amps and it is working fine and we check the alt and is a 70
Old 05-31-2010, 10:12 AM   #6 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
your camry running more electronics and support items so your car it self has a higher demand (ie you have 65w(9006) low beams your bro has 55w(H3) so your losing 20 more watts there ~1.75 amps)
1100w = ~92AMPS so if your blowing 100 amp fuses something not right is the amp the only thing on that line?
so
a.you can take your alternator to a local rebuilder they can normally cram in larger guts taking it to around 100amp cheaper than buying a custom alternator setup
b. optima and a batter charger
c. nickle and dime every watt you can (led bulbs is a great way to drop current draw and look nicer and hid retro would give back 5 amps)
d. big 3 like previously mentioned
also i'm guessing rms would be around 825watts? 68.75 amp at max leaving 1.25 amp at redline when playing music too loud
^ and leaving it that way!
Old 06-01-2010, 12:29 AM   #7 (permalink)
how can i check if my alt is giving wat is supose too ?and how much would it b to rebuild my alt for more amp?
Old 06-01-2010, 12:35 AM   #8 (permalink)
96 3MZ M/T
chronoti's Avatar
no idea on the price but if you have good helpful people at your local part store and their not busy the free battery and alternator test will give you that information
Old 06-01-2010, 12:37 AM   #9 (permalink)
ohh i'll see then thanx
