Amp and HID On Battery Together: Ok?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2010, 08:33 PM   #1 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
It's humiliating to be asking this question, but I haven't had the chance to revert to my halogens yet... I'll try to get them out tommorow just cause now I have to I litterally JUST stepped in from my amplifier install and was wondering: Is it alright if you were to run an amplifier and an HID kit, both off the positive terminal of the battery? Dunno, I feel like the terminal would melt or something Any input?
EDIT: Also, let me ask you guys this since I'm on the topic of the amplifier, I haven't had the chance to fine tune the amp yet, but I seem to be getting Bass only on the front, sound + bass on the rear. Is that normal, or did I wire something wrong???
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 05-31-2010, 08:35 PM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
It should be fine...but with the car running, amp on, and lights on, check the voltage at the battery. I'd be more concerned about your alternator handling it but I doubt it would cause a problem.
Chris Crash is online now   Reply With Quote
Old 05-31-2010, 08:39 PM   #3 (permalink)
TN's Mad Chemist
Hmm I'll take the ohmeter at the battery tommorow morning, I'm assuming above 11-12V should be fine? Should I test alternator output as well?
Also, I'm really concerned about the second part: I'm really only getting Bass in the front. I checked the wiring and everything is alright, should I bridge the speaker connections? The amp is a 4 channel amp...
EDIT: Ah sorry you said at the battery
1997 Acura RL-Gone
Old 05-31-2010, 09:01 PM   #4 (permalink)
Running it should be like 13.6 if I remember correctly. But above 12 basically.
I would definitely test the alternator while it's running. No idea the specs on that though, check the FSM.
I know nothing about amps so can't really help you there, but I don't think bridging it would help. Someone else who knows more can help you though.
The Following User Says Thank You to Chris Crash For This Useful Post:
projektvertx (05-31-2010)
Old 06-01-2010, 01:01 AM   #5 (permalink)
Gameroom cash: $160710
View FLIP K1DD's Photo Gallery
depends on how many watts your amp is pushing..the only main problem i can see is the HID start-ups..which is pretty high if i can remember correctly. Ive been running my HIDs + 200w AMP for about a year now and its fine. I was pushing a 1000w amp befoer, but leme tell you first hand that its a bad combo if your wiring, battery, alternator is stock.
FLIP K1DD is online now   Reply With Quote
The Following User Says Thank You to FLIP K1DD For This Useful Post:
projektvertx (06-01-2010)
Old 06-01-2010, 07:24 AM   #6 (permalink)
TN's Mad Chemist
The amp itself (4 channel) is rated at 111W RMS per channel, but my speakers are 35W RMS in the front, and the rears are rated at 30W RMS. So I assume that's how much they are drawing... I re-wired all new 16 gauge speaker wire throughout the car and wired some 8 gauge power wire and ground wire. The battery is not stock, it's an older (7 years) Die Hard Gold.... Pretty much, the only thing that's stock, really, is the alternator...
I guess my best option would be to take out the HID kit altogether
Any advice on solving my tuning issues Flip?
1997 Acura RL-Gone
Old 06-01-2010, 08:30 AM   #7 (permalink)
PortugalFocus's Avatar
Gameroom cash: $124395
View PortugalFocus's Photo Gallery
That should be just fine. I am running HIDs with a 400w RMS amp for about 9 months now with now low voltage or dead batteries.
PortugalFocus is offline   Reply With Quote
The Following User Says Thank You to PortugalFocus For This Useful Post:
Old 06-01-2010, 10:56 AM   #8 (permalink)
TN's Mad Chemist
Thanks! That's reassuring... I just did all of the final audio adjustments on the amplifier. I realized I'm also an idiot I figured out where I went wrong:
1. I switched the Rear RCA's with the Front RCA's at the amplifier
2. I had the Low Pass Filter on the highest setting for the rear at my headunit So all it was sending was the Bass Total dumba$$ mistake there!
So now everything is in full functioning order, I adjusted it to sound great with no distortion at a bit above the max volume where I would set it I just need to tuck away my RCA wires and I'm golden Thanks for the input and reassurance everyone
1997 Acura RL-Gone
Old 06-01-2010, 12:01 PM   #9 (permalink)
Good job on trouble shooting the issue. Sometimes it's the small stuff we miss that cause the biggest headaches.
Old 06-02-2010, 06:15 PM   #10 (permalink)
werkit217's Avatar
View werkit217's Photo Gallery
You should should be money with the HID's n the amp, I have a 5 channel 1000 watt amp and HIDs, no issue whatsoever
I build cars the way I build them, anybody who thinks any different, well... they're just wrong
werkit217 is offline   Reply With Quote
Old 06-02-2010, 09:56 PM   #11 (permalink)
TN's Mad Chemist
Thanks Too true!! This is also my first amplifier install, and considering all of the hurdles I had to go thru in the wiring, it's surprising the wiring was perfect on first fire up! It's really neat that it was just a settings issue And now, I am super proud of myself, and it makes it all that much more enjoyable to listen to it
That's reassuring, thanks for the input I'm actually about to put in some 60W RMS Infinity Reference 6022i in the front tommorow, so that is comforting
1997 Acura RL-Gone
Old 06-04-2010, 06:45 AM   #12 (permalink)
TN's Mad Chemist
Well guys I removed the HID kit last night Thanks for the input and helping me bridge and operate my car in the time I had an amp and an HID kit together
1997 Acura RL-Gone
Old 06-04-2010, 10:54 AM   #13 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
I hope you're only removing the HID kit because of "improper" light output and not power draw.
Per side, my HID retrofit draws 13A only briefly on power up. Once it settles down it draws less than 4A, 1/3 less than halogen bulbs. So electically it should be easier on your car. Now I used the good stuff - big Philips 35w ballasts and FX projectors. Got my numbers through a DC-capable clamp meter.
Bottom line - don't hit bass while turning on the HID and you'll be fine.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 06-04-2010, 11:41 AM   #14 (permalink)
TN's Mad Chemist
Originally Posted by Buurin View Post
I hope you're only removing the HID kit because of "improper" light output.
That's exactly why I pulled it out actually I don't want to blind people. I just threw back in ye ol' Sylvania Silverstar Ultras I mean, you'll be able to see the system on Saturday I really want to have a chat with you about doing a retrofit on my car
1997 Acura RL-Gone
