The smelly mystery continues... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2010, 08:21 PM   #1 (permalink)
View Novice_cardude's Photo Gallery
I posted a while back asking about possibilities for a burning rubber smell i would experience quite intensely when at a stoplight or in my garage after driving for a few miles. It was suggested that I check for oil burning off the block, anything stuck to the exhaust, etc.
A week or so ago I lifted my car to check it out. There's nothing on the exhaust, the oil leak is very slow, all the suspension parts are in their proper place (at least at rest), and the tires aren't rubbing anything.
I'm pretty sure I tracked down what's actually making the smell. My left front tire. I looked at it, and the inner edge was toast, the entire outer tread block was gone. The outer edges on both tires are worn to 0/32, but the inner edge on the left front was pretty bad. Also the tread wear sloped almost like a camber wearing problem.
Because my state inspection is due, and i'm one of those honest state inspectors, I decided to replace my front tires before passing it. I also put it on the alignment rack. Every angle was well within spec, again with the car at rest.
On the way home, I didn't smell that burning smell. Once I parked, I sniffed both tires (yes, I looked like a retard, no I don't think anyone got it on camera). The left front is already wearing the nubs off, while the right front doesn't seem to have that going on yet. Also the left front smells like it's getting a lot hotter.
This could be my imagination, but I don't want to risk burning these tires up too.
Any ideas on what could be causing this? I'll throw out my theories.
First, I know the lower control arm bushings are OEM, and worn a little. Is it possible that the torque from the axle is throwing them one way or another while the vehicle is in motion? If so, it would change camber and caster and toe, but you'd think I would hear or feel a 'clunk.'
Second, i've seen it mentioned here that the driver's side axle varies in length from ABS to non-ABS on the 5-spd. Mine's a 5spd non-abs, but the axle I recently put in has an excitor ring on it. I don't put too much stake in this theory because if the axle was pulling the knuckle that hard, it should show up on the alignment rack, right? or would that be another in-motion scenario?
Third, The springs on the car are OEM as well. Because it's been a single person commuter vehicle for so long, it seems like the left side, especially the left front, is sagging. I don't know what bearing this would have on burning a tire up, but it will affect camber when i'm driving it. Again, the angles at rest are perfect ...
This ties into my final theory. It's a single person commuter car, and I drive it hard. I mean I use every bit of torque that 5s-fe has when I get the car rolling. I shift at 2200 or 2300 rpm, and bury it from there. This is not how most 4-cyl engines are supposed to be driven, but the 5s pulls it off nicely. Because the driver's side axle is shorter than the passenger side, it's going to get more power to the left front tire, and that tire will be doing a lot of work. That would explain the difference in temperature, as the left front is doing all the pulling, while the right front mainly turns and stops. If this is the case, i'd be surprised if it was just my driving causing it. Is this the early sign of differential failure?
As you can tell i've had a lot running around my head about this. It's just perplexing to me that the left front is burning up so fast. Even if it was angles changing dramatically during motion, the toe change would cause wear to both front tires, not just one.
Any input or additional theories would be much appreciated. I'm flying blind here.
Thanks!
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Old 06-02-2010, 08:24 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
front left wheel brake dragging ?
Old 06-02-2010, 08:39 PM   #3 (permalink)
Wow that's so simple i'm embarrassed I didn't think of it...
I noticed the right front pads were wearing just slightly faster than the left front, so I doubt that's the case, but I will check tomorrow. I'll have it in the air again for some other junk.
Just goes to show what simple things you can miss if you dig too far into a problem like this
'96 4cyl 5spd Camry
Old 06-03-2010, 08:37 AM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
oh yeah ... hehe ... if i knew all simple things i missed throughout the years
if brake pads wear uneven then at least re-grease the caliper sliding pins or replace them with new ones and then put some new good high temperature grease.
it might be that one of caliper pistons doesn't move freely and causes brake pads to drag on rotor.
good luck!
Old 06-03-2010, 09:54 PM   #5 (permalink)
Well, I had 'er up today, welded a new flex pipe in, and checked out the brakes. They all appear to be wearing evenly, and the slide pins move freely. I re-lubricated them and worked the caliper pistons in and out a few times, did a bit of a brake flush. On the way home I couldn't smell the rubber too much, but it was still there. I wonder if this is just new tire smell and i'm over-reacting?
Now that the exhaust leak is gone and the engine is quiet as a mouse, I can hear the tires on the pavement with my window down. It's so hot i can actually hear the rubber sticking to the pavement and gurgling like a slick down a drag strip...
I haven't noticed any uneven wear as far as how the new tire nipples are disappearing. They're not scrubbing off the left front any faster than the right front. I might have inadvertently fixed the issue, or perhaps it was just a bad tire before and i'm amplifying the smell in my head ...
time will tell. Only more road testing can reveal if there is still an issue.
Thank you once again for pointing out the brakes as a possibility. I figured I was missing something stupid.
'96 4cyl 5spd Camry
Old 06-03-2010, 10:07 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
no worries, if it wasn't fixed and is serious it will come back with the full force of the dark side
personally i don't think that new tires have anything to do with the smell unless they are burning hot
i have a tendency for "amplifying things in my head" as well, some people call that anal-ytical thinking
just a thought, maybe the hot exhaust gas leak from flex-pipe was heating up some rubber parts around it ?
for now enjoy driving your ride
