Power steering fluid leak from cap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2010, 07:42 PM   #1 (permalink)
View jempol's Photo Gallery
Hi guys, I need some advise here.
My Camry 94 XLE V6 leaking power steering fluid from the cap, do you think the cap is the problem or something else since I read another thread in this forum that the poster missing the power steering cap and just use plastic and rubber band to cover it.
Do I need specific power steering fluid for this Camry? I just grab regular power steering fluid from Autozone to refill it.
Where I can find power steering cap replacement other than dealer, I called they have to do special order just for the cap.
Thanks a bunch!
jempol is offline   Reply With Quote
Old 06-03-2010, 08:54 PM   #2 (permalink)
96 es300 2mz-fe
Gameroom cash: $135325
View Brandoe91's Photo Gallery
Your car uses Automatic Transmission fluid( dexron II or III).Regular power steering fluid will break the seals within the power steering hoses.As for the cap check ebay or your local junk yard.I think you can also get the cap from a 92-96 es300.
Brandoe91 is offline   Reply With Quote
The Following User Says Thank You to Brandoe91 For This Useful Post:
jempol (06-07-2010)
Old 06-03-2010, 11:52 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If you did not overfill and the Dexron III type ATF is at or below the MAX line, then nothing should leak out.
BTW, you don't feel any steering problems do you? I wonder if there are problems in the fluid circuit if the ATF overflows as you turn.
Thanks a bunch!
Old 06-04-2010, 12:11 AM   #4 (permalink)
Thanks Brandoe91 for the info. Do you think the leak because the cap going bad? I just bought this car recently from a friend and it has this leaking problem before. arrghh... I added regular power steering fluid last time. Stupid me not to check the cap for guidance, now I have to flush the power steering fluid.
Old 06-04-2010, 12:19 AM   #5 (permalink)
I just feel the steering a little bit heavier than my other car, but for sure the fluid leak from the top reservoir, maybe the cap going bad?
Also I added regular power steering fluid last week, is it dangerous?
Old 06-04-2010, 01:05 AM   #6 (permalink)
Some systems use ATF while others use PSF. I really don't know the reason one way or the other. Some Fords use Type-F yet other Fords use PSF. So dunno.
However, your system takes GM Dexron III type ATF. Don't use the new Dexron VI, it's too thin.
That said, as I suspected you may have an internal fluid problem with the steering system. If you can verify that the steering is harder than other similar Camrys then I would check the pump or the rack and replace as necessary. Otherwise you can suddenly loose more or all steering assist when you most need it.
In short, the problem with the pump or rack would pose a more immediate hazard, IMO.
The Following User Says Thank You to JohnGD For This Useful Post:
jempol (06-07-2010)
Old 06-04-2010, 04:06 PM   #7 (permalink)
Gameroom cash: $303755
I agree with JohnGD. Worry about the pump and the rack first. Since you added regular power steering fluid to the car, I would flush it all out of there first. Then add the right Dexron for your car. Your owner's manual actually calls for Dexron II, but that is no longer available. Use the Dexron III or something that meets the Dexron III requirements.
As far as the cap is concerned, I had a similar problem on an 86 Camry. If the cap is like that car there is an O-ring in the cap. If so, remove the O-ring from the cap carefully and take it to any auto parts store and match up the O-ring and get yourself a new one. This 50 cent fix might be all it needs.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
jempol (06-07-2010)
Old 06-04-2010, 04:53 PM   #8 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
IME when the fluid gets aerated or full of moisture it will rises higher with lees work load or temperature increase then it can easily overflow a resovoir.
That points back to starting with the proper fluid as mentioned above.
But, obvioulsy go with cap if it doesn't fit right or has some form of defect.
73sport is offline   Reply With Quote
Old 06-06-2010, 09:25 PM   #9 (permalink)
I just replace the reservoir fluid with Castrol ATF DEX3 and clean the cap.
Here is the cap looks like:
Let see if this will fix it. I don't know how to flush the fluid with the DYI guide since this reservoir have 4 connection.
which one is the return hose?
Old 06-07-2010, 12:50 PM   #10 (permalink)
V8'sRGone
73sport's Avatar
Sorry can't tell you which one, but you might look here. It shows a confusing picture plugging three of the four holes! But your pump has two suction ports so I expect two of the those lines should be lower on the tank.
http://www.camrystuff.com/manuals/Gen3/sr.pdf Page 26
Things to look for:
Because its a reservoir, the return line(s) will be up higher on the reservoir while the suction line(s) to the pump will be lower in the sump to pickup liquid in the resovoir. You want the high lines not the low ones.
Also, because yours has the cooling fans runnig off the PS pump, it'll be a little harder to get all the old fluid out in one flush. Meaning, you might have to flush it, drive it and repeat at least once after the fans come on. It all depends how thorough you want to be.
If it ran low on fluid it could haved sucked air which would likely create foam which then spilled over from the vented cap. Also, old fluid could have lost its anti foaming ingredients AND mixing fluids could make foaming worse.
The Following User Says Thank You to 73sport For This Useful Post:
jempol (06-07-2010)
