Spark Plugs on Camry 94 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2010, 06:07 PM   #1 (permalink)
Gameroom cash: $120300
View johnjan's Photo Gallery
Can someone please post a picture of the location of spark plugs on a Toyota Camry LE 94?
Thanks
johnjan is offline   Reply With Quote
Old 06-05-2010, 08:56 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
If you have a I4, then they are sitting right on top of the engine....
2007 Camry 2.4L 5M
Old 06-06-2010, 08:12 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
FOLLOW THE PLUG WIRES 5sfe
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 06-06-2010, 08:14 PM   #4 (permalink)
The 4 HOLES IN THE VALVE COVER
Old 06-06-2010, 08:23 PM   #5 (permalink)
Gameroom cash: $130305
View Gonzo64's Photo Gallery
Clean engine bay! Looks brand new probably can eat off it!
Gonzo64 is offline   Reply With Quote
Old 06-06-2010, 08:39 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Also, I'd use NGK Iridium-IX plugs.
Thanks
The Following User Says Thank You to JohnGD For This Useful Post:
johnjan (06-10-2010)
Old 06-14-2010, 07:24 PM   #7 (permalink)
Are there more than just these 4 spark plugs in a 94 Camry LE?
The DIY thread talks about plugs under the intake manifold.
Old 06-14-2010, 11:46 PM   #8 (permalink)
That should be the V6. 3 are staring right at you (front bank), and 3 are under the intake manifold towards the firewall.
I'd recommend getting a torque wrench from Harbor Freight to properly torque the plugs. If you use a small dab of antiseize 3 threads away from the firing tip, reduce the torque to 13 lb/ft from 18.
The insulator body is ceramic. And over-torquing can stretch the metal casing and crack the ceramic inside.
Read more about torque values:
http://www.ngksparkplugs.com/tech_su...e.asp?mode=nml
and other NGK FAQs:
http://www.ngksparkplugs.com/tech_su...x.asp?mode=nml
http://www.harborfreight.com/3-8-eig...rench-807.html
johnjan (06-15-2010)
