As I know it, the passanger side is not serviceable and is different from the drivers side as in it holds a higher standard (more tumblers??). Something about it being the master. Thus, if you have keys made from old keys, make sure they work smoothly in the passenger door 1st! Then check the drivers door, ignition and finally the trunk.
The point being a worn out copy may work everywhere but the passenger door.
To your point, if you can find a drivers door lock, I think it can be re-keyed. But check with your local locksmith or buy a new one from yota as said above.
