A/C Compressor 1997 Camry LE 1MZFE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2010, 12:10 AM   #1 (permalink)
View gorak's Photo Gallery
Engine is stalling when I run the A/C. I assume the compressor is locking up? Any reason as to why this may have happened? My mechanic is saying its going to be an $800 fix and that in addition to replacing the compressor, the receiver/drier also has to be replaced. Is this a hard DIY if I can have the r-134 evacuated at a local shop and then replace all the necessary parts myself? I know it involves taking the drive belt off.
gorak is offline   Reply With Quote
Old 06-07-2010, 03:20 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
yes easy diy search on google for the camry fsm (camry stuff i believe is the site) you can just dump the r-134 in to the environment but you will need a shop to pull a vacuum on the system post change out. also double check on iacv (search) to make sure that can rev up the engine i dont see a locked compressor stalling an engine maybe causing crazy amounts of smoke from belt slip.
^ and leaving it that way!
Old 06-07-2010, 05:24 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
http://www.epa.gov/Ozone/title6/608/faq.html
If you have no A/C equipment, experience or knowledge then you best let a shop do this. You can save a little labor by having the shop re-capture the 134a and replace the compressor and receiver/dryer yourself, but refilling properly is best left to an expert. You can also source aftermarket compressor and receiver dryer here:
http://www.acsource.com/index.aspx
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 06-07-2010, 03:23 PM   #4 (permalink)
That's what I was talking about, having a shop remove the refrigerant and depressurize the system so that i can remove the compressor, and receiver/drier. Does anyone have a DIY on how to remove the compressor and receiver/drier?
