How much transmission fluid is needed for camry V6 (97 - 01) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2010, 10:07 AM   #1 (permalink)
View zq_frank's Photo Gallery
Does anyone know how much trans fluid is needed for 1997 - 2001 V6 camry?
I am having the problem with the transmission fluid level. My car is 99 camry v6. I changed the trans fluid according to the mark on dipstick, but the transmission seems not correct, I can feel the transmission stuck and acceleration is slow.
In my user manual, it says the drain and refill should take 4.75 liter trans fluid, but after I did that, the fluid level is much higher than max hot level on the stick. I asked so many people and technicians, but still can not get a clear answer. Most people say the dipstick is correct, you should add the fluid based on it, but it seems nobody cares about the total amount, even everyone knows it is hard to read the trans fluid level.
Does anyone changed trans fluid just based on this drain and refill amount?
Here is the detail spec copied from my user manual and repair manual:
The drain and refill is different from the dry fill, right?
AUTOMATIC TRANSAXLE
1MZ–FE engine
Fluid capacity (drain and refill),
L (qt., Imp. qt.):
Up to 4.75 (5.0, 4.2)
Fluid type:
Automatic transmission fluid D–ll or
DEXRONIIl (DEXRONII)
Automatic transaxle fluid:
Dry fill
6.75 liters (7.10 US qts, 5.94 Imp.qts)
5S–FE engine
L (qt., Imp. qt.):
Up to 2.5 (2.6, 2.2)
Fluid type:
Differential
Fluid capacity L (qt., Imp. qt.):
1.6 (1.7, 1.4)
Fluid type:
Automatic transmission fluid D–II or
DEXRONIII (DEXRONII)
Automatic Transaxle Fluid
(w/o Differential Fluid) Dry Fill L (qt., Imp. qt.):
5.6 5.9 4.9
zq_frank is offline   Reply With Quote
Old 06-07-2010, 09:25 PM   #2 (permalink)
Engineer, tinkerer
View arlo's Photo Gallery
I have a '97 V6 and last time I changed the transmission fluid it was almost 4 qt exactly. This included dropping the pan and changing the filter. I basically just measured how much I took out, and added that much back in of fresh oil.
1997 V6 auto 160,XXX
1993 I4 auto 133,XXX - Blown transmission; Sold
arlo is offline   Reply With Quote
