Scratched/scored spark plug tube 99 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2010, 02:50 PM   #1 (permalink)
View swellstoynation's Photo Gallery
I was following the advice on this post regarding removing and sealing the bottom of the spark plug tube due to oil in the tube.
However, I was not as successful with the pipe wrench as the original poster, so I have some score marks/scratches on the spark plug tube. Scratches are only on the outside of the tube itself, not on the threads.
My question is: Am I okay to reinstall the tube and run this way or do I need to replace the tube so that there are no score marks on anything inside this area?
Thanks,
~A learning-as-I-go DIYer whose projects always cost 2x projected $$$ and take 2x projected time.
swellstoynation is offline   Reply With Quote
Old 06-07-2010, 10:07 PM   #2 (permalink)
Gameroom cash: $303755
As long as there are no burrs of metal or sharp edges that might fall off inside the cam cover, you should be OK. If there are, sand them off before reinstalling.
Mike
Old 06-07-2010, 11:05 PM   #3 (permalink)
Thanks for your help.
btw, anybody know the torque specs for those tubes? Or where I look for that info?
~An appreciative newbie.
Old 06-08-2010, 09:56 AM   #4 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
If there right at the top of the tube where the valve cover seals, that would be bad and it would likely leak. Replace if damaged at the end.
Beyond that, use toyota recomended sealent (not cheap RTV), remove the burrs and put it back to together.
73sport is offline   Reply With Quote
Old 06-08-2010, 04:59 PM   #5 (permalink)
"If there right at the top of the tube where the valve cover seals, that would be bad and it would likely leak"
73sport makes a good point. I hadn't thought about the score marks being near the top where it seals.
Mike
Old 06-08-2010, 05:59 PM   #6 (permalink)
V8'sRGone
73sport's Avatar
You only mention 99, so take a look here.
http://www.camrystuff.com/index.php?page=Gen4_Manuals
Toyota Gen4 (1997-2001) Camry Repair Manuals
Many thanks to "DrXenon" on ToyotaNation for providing these manuals.
Note: * indicates file contains one half for 5S-FE, one half for 1MZ-FE
Electrical Wiring Diagrams (6.3MB, 365 pages)
Gen 4 Collision Repair Manual (12.6MB, 113 pages)
Miscellaneous files:New Car Features (changes compared to the previous model year)
  • 1997 (2.4MB, 116 pages)
  • 1998 (380KB, 56 pages)
  • 1999 (552KB, 76 pages)
  • 2000 (376KB, 44 pages)
  • 2001 (68KB, 6 pages)
Old 06-08-2010, 06:02 PM   #7 (permalink)
V8'sRGone
73sport's Avatar
Something to add to this:
If you use a pipe wrench, I'd suggest putting something inside the tube to prevent from crushing it. Maybe a deep well socket or even a wooden dowel could give it enough strength to prevent crushing it if its stuck!
Old 06-09-2010, 07:14 PM   #8 (permalink)
The manual actually shows just using the top of the valve cover washer and a 30mm socket to install the spark plug tube. So a pipe wrench or vise grips aren't necessary for reassembly.
Many, many thanks for the resources and your patience with someone who is new to the forum! I had tried searching through for an answer to my particular question without success. Appreciate it.
Old 06-09-2010, 09:32 PM   #9 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
my 93 camry with almost 300k miles had oil inside spark plug tubes a year ago, i am not sure what seal is suitable in that area, but instead of sealing, i used a medium size channel lock plier, and tighten each spark plug tube by 1/4 turn, and yesterday, i changed spark plugs and all were dry.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 06-09-2010, 11:07 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
i think you can actually use 2 tube nuts together on a tube's thread (nuts facing away from each other, kind of the bottom one upside down) then you can a wrench/socket on them. there was a thread with pics on this. hopefully you know what i mean as my wording is not super precise hehe.
