Oil additive to stop leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2010, 11:50 AM   #1 (permalink)
Quattrovalvole's Avatar
View Quattrovalvole's Photo Gallery
Hi
I have a nasty oil leaking in my engine and I haven´t been able to locate it honestly.
What you guys think of the oil additives to stop leakings? Would you recommend it?
Your comments are really appreciated.
Thanks in advance.
_______________________________________________
1997 Camry LE V6
16' Enkei's
Pura vida from Costa Rica
Quattrovalvole is offline   Reply With Quote
Old 06-08-2010, 12:12 PM   #2 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
3 words!
Don't Do iT!
It may slow it down now, but when its done evaporating it will leak even worse! Find the real leak. Mirrors, lights, take it to the shop. . . Find the source and fix it.
73sport is offline   Reply With Quote
The Following User Says Thank You to 73sport For This Useful Post:
Quattrovalvole (06-08-2010)
Old 06-08-2010, 12:15 PM   #3 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
Yup, just bite the bullet & fix it!
ricamryman is offline   Reply With Quote
The Following User Says Thank You to ricamryman For This Useful Post:
Old 06-08-2010, 12:47 PM   #4 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
dont do it... 73sport is right (as usual!)..
Here's my story for engine leaks:
I had a terrible distributor leak. Pulled out the distributor and its leaking from inside (not the regular distributor o-ring). My only chance was rebuilding the distributor. I was running 5W30 that time to clean up some suspected sludge. Running 5W30 for 3K miles was good enough to tell me just how many god damned leaks were present in my 5SFE...I would never do that again.
Anyways before I rebuilt my distributor I decided to try High Mileage oil thats supposed to be thicker.
And man within first 200 miles of Pennzoil High mileage 10W-30 the distributor leak has slowed down considerably :-)
I am hoping within next 1000 miles it will completely stop the distributor leak or make it real slow.
Bottom line:
Please dont add any magic potion to any of your cars fluids (Engine Oil,Transmission Oil,Power Steering Oil, Anti-Freeze) except washer fluid ...ha ha.. :-D
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
The Following User Says Thank You to peshwa For This Useful Post:
Old 06-08-2010, 01:15 PM   #5 (permalink)
Gameroom cash: $220750
View Throck's Photo Gallery
Take it to someone who knows what they are doing. It's my understanding that many of the "oil leak preventatives" cause seals to swell in order to stop leaks. That may work for the short term, but the seals will either give or harden and then you have a bigger problem on your hands.
Throck is offline   Reply With Quote
The Following User Says Thank You to Throck For This Useful Post:
Old 06-08-2010, 01:33 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
there is a few option a shop may try to pinpoint the leak, e.g. UV oil additive, smoke test, cleaning engine a bit to see when fresh leak appears, etc. etc.
do not add any bullshit Stop Leak into engine, over time you will regret it as most likely the leaky gasket will be wasted completely by the next oil change.
The Following User Says Thank You to fenixus For This Useful Post:
Old 06-08-2010, 02:17 PM   #7 (permalink)
Well, since I´ve been running with 20w-50 given the weather here in Costa Rica I have to suppose that my leaking is worst than it looks in this moment.
Thank you guys for all of your words and good advise.
No additives for the engine at all.
1997 Camry LE V6
16' Enkei's
Old 06-08-2010, 09:09 PM   #8 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
^ Holy moly, you use 20W-30!?!?! I thought that was for diesel engines only Yeah, stop leak additives will only mask the issue temporarly and some may potentially cause long term sludge build up. Spend that money on a nice set of diagnostic tools instead, they last much longer
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
