Quick 1MZ O2 Sensor Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2010, 04:33 PM   #1 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
1997 Avalon XLS that i'm working on for a family member. CEL was on and I read the code as P0135.... "Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)". I assume that the sensor in the header on the side of the engine that faces you when you open the hood needs to be replaced. I just want to be sure which one of these parts I need to get. OEM Denso I suppose is the best. Here is the rock auto link. Thanks!
'07 Honda Ruckus Big Bore
Old 06-08-2010, 04:42 PM   #2 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Notta - that'd be the hard to reach one by the rack & pinion not the easy one in the front!
73sport is offline   Reply With Quote
Old 06-08-2010, 08:00 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Yup. Bank 1 is the rear bank, not the front. I replaced that one in my Avy a while back, and it's not as hard as it looks. It helps to have skinny arms (I don't) and a good assortment of 1/2" extensions. I might have used a u-joint too; don't remember.
And yeah, the OEM sensors are Densos, which is what quite a few of the folks on ToyotaNation swear by.
BMR is offline   Reply With Quote
Old 06-08-2010, 08:12 PM   #4 (permalink)
Freakin Scooters
BAHHHH dang it. So which part do I need?
edit: DENSO Part # 2344209 ?
Old 06-08-2010, 10:16 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
for oem/denso part check www.toyodiy.com/parts (give it car's VIN for best results)
or go with NTK/NGK sensors which seem to be better over Denso:
http://www.ngksparkplugs.com/part_fi...uv/default.asp
you can get them cheap on amazon.
Old 06-08-2010, 10:24 PM   #6 (permalink)
Freakin Scooters
Thanks! Okay pre-cat non cali O2 sensor. Right bank = Bank 1? or am I wrong?
Old 06-08-2010, 10:35 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
pre-cat non-cali would equal to upstream federal (narrow band thimble type).
i'm not familiar with right and left sides of a V6 LOL
... but i know that "engine's front" is actually where the timing belt/chain side is so i guess when you facing "engine's front"/t-belt side then the LEFT hand side is bank 1 (so called rear bank haha) and the RIGHT hand side is bank 2 (so called front bank LOL).
don't quote me on this
Old 06-08-2010, 10:48 PM   #8 (permalink)
Freakin Scooters
^ Yep, upstream federal that I understood. I just need to know which bank.... left/right..... bank 1 is. I'll PM some peeps.
Old 06-08-2010, 10:59 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
I bet you need LEFT = bank 1 = commonly known as the rear bank
^ double check it
edit: corrected wording in above post to make it sound more logical.
Old 06-08-2010, 11:21 PM   #10 (permalink)
Freakin Scooters
^ EXACTLY what I wanted to know. LEFT bank = Bank 1 = Rear Bank = The side of the enigne with cyl # 1. God I hope this info helps someone some day.
edit: WAITTTT. can anyone confirm this?
Old 06-09-2010, 07:58 AM   #11 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
Here' ya go, confirmation, with pictures no less.
ajkalian is offline   Reply With Quote
Old 06-09-2010, 10:34 PM   #12 (permalink)
Freakin Scooters
Errr, thanks for the pic... but we need to be sure that Bank 1 is the LEFT bank.
Old 06-10-2010, 01:02 AM   #13 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
I dunno which bank would be called left?... it depends on which side of the car you're standing.
I *can* say that bank 1 is the one closest to the firewall.
Old 06-10-2010, 10:06 AM   #14 (permalink)
V8'sRGone
73sport's Avatar
Perspective is always from the rear of the engine i.e. from the bellhousing to the timing belt.
bank #1 = Right side (by rack and pinion)
1, 3, 5 = bank1
bank #2 = left side
2, 4, 6 = bank2
But who cares, they're both the f'g same P/N! Ok - on the old stuff at least. . .
EDIT EDIT EDIT - - sonn - of - a gunn. . . That picture Really needs to marked WHAT YEARS it APPLIED TOO!
The Following User Says Thank You to 73sport For This Useful Post:
LynchburgCSI (06-10-2010)
Old 06-10-2010, 10:13 AM   #15 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
sensor 4209 requires you to put own connector on.
Remove intake air hose, and you will have lots of room!
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
