caution lights stay on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2010, 05:55 PM   #1 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
Ok I just noticed that every time I turn on my hazard lights, they blink in normal operation, then after a few blinks they stay on. Does anybody know what is happening?
RU2CHKN is offline   Reply With Quote
Old 06-09-2010, 06:11 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
I've not ever heard of this problem!
Are all the bulbs in working order? Anyway you can borrow another panel to test the switch?
And Lastly, probably the problem is there is an actuator/blinking relay in the fuse box in the engine bay which might be damaged. I forget if the emergency blinkers is the same as the turn blinkers, so do it do the same when you use the turn signals?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 06-09-2010, 10:58 PM   #3 (permalink)
RU2CHKN?
RU2CHKN's Avatar
The turn signal did it occasionally today but not as frequent as the caution lights
Old 06-09-2010, 11:02 PM   #4 (permalink)
Ninja-rator
In the morning or tonight if you have light, take the panel covers from both the box in the engine bay and at the driver's left knee. See where either light relays are and pull them out (one at a time) if the neither function stops working, I'm sure the fix is to replace that particular part.
Also might be some wires being dislodged and or damaged, check them also.
Old 06-09-2010, 11:02 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
sounds like relay is getting stuck. try knocking on it to see if the blinking lights return to normal.
Old 06-10-2010, 08:53 AM   #6 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Ok thanks for the replys how can you tell if the relay is bad?
Old 06-10-2010, 11:42 AM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
well if tapping/knocking on it helps it work right then it's bad.
there are electrical tests you can do on relay, that would require applying battery voltage to certain terminals and checking for continuity on other terminals. details vary from relay to relay. sometimes they have a diagram imprinted on them, so you know which ones are for reference voltage and others would be signaling terminals, etc. etc.
not sure if Haynes or FSM cover those relays, but some electrical diagrams should have it.
have you checked www.camrystuff.com (Factory Service Manuals) ?
Old 06-10-2010, 11:59 AM   #8 (permalink)
RU2CHKN?
RU2CHKN's Avatar
I removed the kick panel cover and start knocking on the relay, it works now. I've only been using the Haynes Manual
Old 06-10-2010, 12:37 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
then you have the answer. relay needs to be replaced with new one. old one is getting stuck.
