96 Camry V6 LE - power lock & a/c problem
1996 Toyota Camry V6 LE, just shy of 200k miles, car still runs great, but had a couple problems that I hope can get some answers and repair tips here..
1. driver side power lock sometimes work and sometimes doesn't...
When it work, it would work just fine, when it doesn't it seems like the power lock is trying to lock/unlock but just doesn't have enough to make the jump..
all 3 other sides and all 4 power window works, the car also lock/unlock w/ key just fine
2. there is also a burning smell coming from a/c vent when set to ventilate air, if move the lever to inside circulatoin, then the burning smell is gone..the burning smell probably is coming from inside the engine compartment and my guess maybe one of the hose has a crack or something
3. light under D (shiftgear indicator) on the odometer and lights under a/c control both are out..I think I can change the bulb for the a/c control but not sure how difficult it will be to change the bulb for the shiftgear indicator
4. there is a rattling sound coming from the front passenger side, I have tried to push the panel, a-pillar, door, but can't figure out where is the sound coming from..
