P/S Fluid Color - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2010, 06:15 PM   #1 (permalink)
Gameroom cash: $125050
View redtigerrocks's Photo Gallery
P/S Fluid Color
94' Camry V6
The power steering fluid looks clear when you pull it out of the container and dab it on a piece of paper but looks dark from the side of the container (also the container is yellowing =( ). Is this normal?? Their is no difference in steering that I feel.
redtigerrocks is offline   Reply With Quote
Old 06-10-2010, 06:28 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
normal store bought p/s fluid is clear, what comes loaded in the car from the dealer is dexron III (red) so thats your reason it's just mixing you wount notice a difference unless you flush the system.
^ and leaving it that way!
Old 06-10-2010, 06:57 PM   #3 (permalink)
Also I have a question about the RMM Gen 3.5 Lip. Will it fit a 94 camry and is it bolt on?
Old 06-10-2010, 07:22 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
you can flush the p/s system easily with like $12 parts from Home Depot and using Castrol Synthetic Blend ATF (Import Multi Vehicle) <- good stuff!
http://www.toyotanation.com/forum/t19334.html
for the second question i suggest starting new thread to keep forums neat & clean
Old 06-11-2010, 12:54 AM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Any Dexron III type fluid is good. I wouldn't use Dexron VI in these, IMO it's too thin. There are plenty of good DIII type fluids out there, one is the Castrol Import Multi-vehcle ATF mentioned (synthetic blend). Another is the Walmart SuperTech Mercon-V that's suitable for DIII too. It has better shear stability than dino DIII. So I'd at least use this in the PS system if not the Castrol syn-blend. The price points of these two fluids are great. No sense going $8-9 for Mobil-1 IMO.
Originally Posted by redtigerrocks View Post
94' Camry V6
