ABS Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2010, 06:30 PM   #1 (permalink)
View djahandarie's Photo Gallery
Lightbulb ABS Light
My ABS light came on the other day in my 94 automatic camry le.
I did check the brake fluid and it was at the correct level so it isn't a bf leak.
Is there a way to pull the code for the ABS light? I checked my manual but it didn't go over any way to do it. I also did a search of the forums but I couldn't find any details.
djahandarie is offline   Reply With Quote
Old 06-10-2010, 07:12 PM   #2 (permalink)
rusty9's Avatar
Gameroom cash: $440905
View rusty9's Photo Gallery
you can check it by using the diagnostic plug under the hood. (which is on the passenger side, near the firewall)
remove the short grey pin plug in the bottom corner first, then using a small piece of wire or paper clip, connect pins Tc and E1(they are labeled on the cap) then turn the ignition to "on". the abs light should blink out a code.
a more in depth procedure and code meanings are in the repair manual pdf. http://camrystuff.com/index.php?page=Gen3_Manuals
rusty9 is offline   Reply With Quote
Old 06-11-2010, 12:56 AM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Sticky vote for ABS diagnostics.
'07 Honda Ruckus Big Bore
The Following User Says Thank You to LynchburgCSI For This Useful Post:
RegularGuy55 (04-10-2011)
Old 06-11-2010, 04:06 AM   #4 (permalink)
Gameroom cash: $326045
View adalex's Photo Gallery
I second that motion
adalex is offline   Reply With Quote
