I had a leak in my '87, couldn't pinpoint where it was coming from, it seemed to be near the filler inlet. I pulled the tank out, still couldn't figure it out. So I cleaned up the outside of the tank and replaced all the gaskets. The problem never came back, I suspect the filler inlet gasket on the tank was bad judging by the condition of the gasket when I pulled it apart, it was dry and brittle.
Another source of a leak could be a bad solder joint but not likely. If you don't have a rusted hole somewhere, the gaskets are likely to be in need of replacement.
