Hello All,
Firstly, I would like to say what a great site. I have been having problems with my Camry lately and came across this site and I think I'm hooked. Thank you for having me.
Now, Down to business. First, my shifter cable is messed up. There is nothing wrong with the cable, but when it goes through the bracket mounted in the engine compartment to the rubber sleeve, it doesnt go straight down. It moves to the side. So instead of pushing the arm down on the transmission, the cable shifts to the side. I looked on google and found nothing. I dont even know how to refer to this part. I will enclose a picture to show you what i mean.
Secondly, My car shakes at like 68-76 mph. But not a normal shake. The steering wheel will rotate left and right rapidly and the whole front of the car shakes. I can hear my glove box door hitting the dash. I would assume this is a front end alignment, but the people at firestone told me the struts wont hold an alignment. This sounded screwy to me; So I figured I would check with the toyota experts here ;-).
Thirdly, Passenger side window will go down fine. Coming up is/was slow and is now EXTREMELY slow to nonexistent. But when I turn the car off and on again, It will go up a little bit. then off and on again, go up a little bit. I read the FAQ and I saw how to replace the motor, I just wanted to verify if this was a common problem or what else It could be. I also read it could be the regulator. Are these terribly difficult to replace?
Finally, the A/C. Just crapped out. I haven't even begun to look into it yet aside from seeing the yellow light blinking and finding out that it means the A/C is broke. Any Ideas what it could be off the top of your heads?
I think that is everything. The engine is fairly new. I had to replace it in like 2005 cuz the dicks at the oil change place messed up and forgot to put the oil plug back in. So I have 145k miles on the car but only about 60k on the engine. My wife and I are on the verge of donating it for a new one, but I would rather do the repairs and have it a few more years if I could. Thanks in advance for all of your help and I look forward to hearing your responses.
Nick
P.S. Ignore the zip ties.... It is my failed attempt at a temporary fix.
You can see how it lines up perfectly while in drive
The cable shifts over instead of pushing the arm down
