Brake Squeal In Reverse - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 3 Old 06-13-2010, 12:22 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question Brake Squeal In Reverse
Hello All
Maybe one of you can give some insight. My rear disk brakes squeal really bad when coming to a stop after backing out of a spot. I just put on some Akebono ProAct pads trying to get rid of the noise. The pins were dry, but they are properly lubed now. I did not change or machine the rotors because they looked very good. I just sanded then with 280 Grit to rid them of the glaze. This did not solve the problem. Even after a proper break in they still squeek in reverse. They are working well and make no noise at all in normal-forward driving and stoping, but they squeal badly enough to break glass when stoping in reverse...Any ideas would be appreciated.
2000 LE V6
jon1000 is offline
post #2 of 3 Old 06-13-2010, 01:06 AM
96 3MZ M/T
chronoti's Avatar
Quoted: 0 Post(s)
pull the rotors behind them is a set of shoes for the parking brake thats prolly where your issue is
^ and leaving it that way!
chronoti is offline
post #3 of 3 Old 06-13-2010, 01:17 AM
V8'sRGone
73sport's Avatar
Quoted: 0 Post(s)
Juat do a qucik double check and make sure the wear indicator isn't bent in on the rotor by accident. If that isn't it, did the last pads wear flat from end to end or were they more sloped?
Thats the only time it squeals for/aft is if not parallel to the rotor. . . Does that make sense?
73sport is offline
User Tag List
Linear Mode Linear Mode
« Back
