Cold start issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2010, 06:36 PM   #1 (permalink)
Gameroom cash: $115300
View TCam01's Photo Gallery
Cold start issue
So recently the car has been having trouble starting up when cold it cranks but doesnt start the rpm rises to about maybe 100 or so and really struggles to start but wont start. The only way i get it to start is to give it gas then it starts an runs like a champ also when the cars warm it does not have the problem yet... does any one know what im dealing with here. I had a similar problem but it was the gunk in the TB and i had to HOLD the gas to keep it running i had an air induction cleaning about 4K miles ago an its been fine until now.
Yota Camry 2001 5S-FE 105,430 Miles+
TCam01 is offline   Reply With Quote
Old 06-14-2010, 07:14 PM   #2 (permalink)
View camry6's Photo Gallery
Check out the cold start injector located on the upper intake manifold/plenum.
camry6 is offline   Reply With Quote
Old 06-14-2010, 09:49 PM   #3 (permalink)
is there any kind of diy or diagram i can look at Ive been looking for one and cant find one anywhere im thinkin that could be the problem
Old 06-14-2010, 10:42 PM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
IIRC, the 5sfe doesn't have a cold start injector. The 3vzfe does. A clogged/stuck IAC valve is usually the cause of cold start problems. I had the same issue with my 96 5sfe. I removed, thoroughly cleaned, and reinstalled the IAC valve. After I did that, no more cold start problems.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 06-15-2010, 12:09 AM   #5 (permalink)
An air induction cleaning doesn't get to that? basically the throttle body was sprayed with something like seafoam 4k miles ago down into that hole. is there a diy for that at all? I know its complicated but if i had something to go by i could deff do it
Old 06-15-2010, 12:30 AM   #6 (permalink)
uibalnme's Avatar
My IAC valve was really gummed up with oily carbon deposits, not even half a can of seafoam helped. I tried every over the counter solvent I could think of, but none helped. Only scrubbing, and carefully scraping the inside of the IAC got enough of the carbon out to properly free up the valve.
You have to remove the throttle body to access the 4 screws that attach the IAC valve to the TB. Then you have to remove the hoses attached to the IAC valve. After you have the IAC valve out, clean with a small bottle brush, and some seafoam or similar solvent. Even rubbing alcohol, and cotton swabs will work for this job.
The Following User Says Thank You to uibalnme For This Useful Post:
TCam01 (06-15-2010)
Old 06-15-2010, 12:40 AM   #7 (permalink)
ok thanks man i honestly hope the iac is the root of the problem and cleaning work's so i don't have to keep troubleshooting like fenixus and his fuel trims lol. I hear you have to lube it up also (haha) after your done cleaning it is that true? Ill keep lookin for a diy because i don't really feel confident removing the TB without knowing what im doing
Old 06-15-2010, 12:51 AM   #8 (permalink)
uibalnme's Avatar
No lube, that will just quickly attract more carbon and dirt. I didn't put any lubricant in the IAC before I reinstalled it. It's been about 5 months since I cleaned it, and haven't had a problem since. Every morning when I start it, the engine jumps to 1000 RPM, then slowly settles down to about 750 RPM as it warms up.
Old 06-15-2010, 12:58 AM   #9 (permalink)
damn that sounds healthy mine jumps to probably 1700 or so then quickly falls down to 1200 till warm but now it wont jump at all unless i give it gas lol if anyone has a thread or website where it shows how to take the throttle body off im sure i can figure the rest out I've been looking for a while now and cant really find anything helpful
Old 06-15-2010, 01:03 AM   #10 (permalink)
uibalnme's Avatar
download all of this...
http://www.**********s.com/camry/
Old 06-15-2010, 12:27 PM   #11 (permalink)
i use this website when it comes to manuals http://camrystuff.com/index.php?page=Gen4_Manuals but i still cannot find anything on the throttle body lol or the iac
Old 06-15-2010, 02:14 PM   #12 (permalink)
uibalnme's Avatar
In the link I posted, file eg1.pdf deals with the 5sfe. Starting at page 45, it shows how to remove the TB.
TCam01 (06-15-2010)
Old 06-15-2010, 03:36 PM   #13 (permalink)
Gameroom cash: $303255
Here's a DIY on cleaning the throttle body and the idle air control valve while they are on the car. I would try this first:
How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
Also, your car does not have a cold start injector nor a cold start time switch. The generation 2 Camry was the last generation to use that setup. Your car's cold start fuel mixture is controled mainly be the engine coolant temperature sensor and the main computer.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
TCam01 (06-15-2010)
Old 06-15-2010, 04:32 PM   #14 (permalink)
Dang dude you always come through you helped me with the exact part i needed for the retrofit i did a while back and youve been a big help with this too. This is exactly what i was looking for thanks man, I will most likely start this week hopefully tomorrow if i can and ill keep you updated and let you know how it goes today it cold started fine but that's the oldest trick in the book when it comes to my camry lol
Old 06-15-2010, 06:13 PM   #15 (permalink)
uibalnme's Avatar
