Originally Posted by ricio
Hi everyone, i need some help with regard to a rear wheel vibration.
It started recently and this is what I have done so far.
I removed the right rear wheel.
I can only turn the disc freely counterclockwise. If i go the other way it locks.
Removed the disc and the hub moves freely in both directions.
The parking brake is worn down and moves slightly to both sides
I am really at a loss as to why the disc locks up.
I appreciate any help
Thanks
Ricio ( Canada)
I have a similar issue with my 93 V6. In my case my parkingbrake sticks (doesn't fully disengage) which rubs on the inside of the RR rotor causing vibrationsand sometimes a slight grinding.
I just stopped using my e-brake since I've noticed the problem until the e-brake shoes come in, hopefully this weekend. I'm going to change the shoes then hopefully an adjustment will fix it (the adjustment is that thing you access via a hole on the RR rotor that looks like a large Phillips head screw).
Not sure if this is your problem (it could be a few things) but maybe it'll give you some ideas to check for. Our gen3's are getting pretty old now, odd problems like this will probably become more prevalent.
