DIY: vehicle speed sensor repair/replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2010, 12:27 AM   #1 (permalink)
View 2000SolaraIL's Photo Gallery
DIY: vehicle speed sensor cleaning/replacement
I recently took apart the entire interior for some deep cleaning and upon full reassemble, I wanted to take my Solara out for a spin. Less than a mile from my house, the speedometer dips suddenly and (BAM!!!) check engine light comes on. Frustrated, I pulled over, popped off the positive battery lead and waited for a few minutes. Reconnected to the battery term and started her up…check engine light gone. Put it in drive and drove a few miles, no problems. Take a fast left turn and the transmission down shifts into first (like I was goosing it), then pops up into second, then quickly into third all while the speedometer dips and jumps for a few seconds.
Took it to Advance Auto Parts for a OBD code read. Got a P0500 - Vehicle Speed Sensor Malfunction. Part # 090-5018 for new sensor from AAP, and more than $150 bucks.
I did have AAP worker clear the CEL. It drove fine around town (taking it easy), but I hit the country roads and tried to reproduce the problem. At cruising speed (40 mph), I could punch it, have it kick down and then, party over, CEL on, speedometer going crazy, and aberrant shifting. Also a little higher idle at a stop. Even on slow takeoff from a stop, the engine would wind out to 3krpm from first to second and second to third, but bog down and shift too early into the high gears. Cool side note though…at cruising speeds, the speedometer would drop to 0 and the odometer would not roll fwd either (trips or total miles). I realized this is not a problem, but a gift that keeps on giving.
Problem was consistent with what I read on TN and other sites (http://www.obd-codes.com/p0500). Was not able to find a DIY for repair/replace, so here’s my rendition. I’m no mechanic, but a cheapskate with a camera.
This DIY is shown for a 2000 Solara SLE (V6 3.0L, auto, 70k miles). I am new to Toyota, so I don’t know what other models this would apply to. I appreciate Eye8Pussies compilation of DIYs. I hope this DIY makes the list.
Tools needed: ratchet wrench w/ extension, 10 mm socket, Phillips screwdriver, light (if needed), thin arm or long fingers (your choice).
The process:
The yellow oval indicates approximate location of the sensor. The sensor is actually located on top of the transmission, close to the firewall (note the thin arm or long finger requirement). I have read that a lot of people have had a hard time finding it, so I posted several pictures.
Off to the driver’s side of the vehicle, you can actually see the sensor under a bunch of hoses, wires, etc. I go ahead and pop off the leads to the battery. Two reasons, first it will clear the CEL and second, I’ve been shocked a few times just messing around and I have heard of some bad stories about screwing up the ECM if accidently short a circuit.
Yellow arrow shows the sensor and red arrow shows the cable connected to it.
Shown is far drivers side view. Outlined in green is flexible hose you can move during this work. Outlined in orange are the rigid brake lines that you shouldn’t bend, break, or mess with.
Up close pic of between the junk you got to work around. Green is sensor. Orange arrow indicates the single 10 mm bolt that must be removed to take out the sensor from the transmission case.
Remove the sensor wire by disconnecting. I basically just squeezed around the base of the connection and pulled straight up. Orange = sensor, red = disconnected wire. If you cannot disconnect the sensor wire, you could use an open end 10 mm wrench and remove the bolt and then the sensor, and finally disconnect the wire. You can see in the next picture the small catch at the connector union that holds the sensor and sensor wire together.
I removed the bolt with my socket and ratchet wrench and carefully pulled the sensor straight out.
Shown is the sensor. Blue is top of the sensor where the mechanical motion is “sensed” by the electrical leads within the unit. Black arrows show the (1) rubber O-ring (replace if damaged) and (2) retaining ring that ensures the rotatable rod makes tight interaction with the internal electrical leads. Green is the gear that, well…moves. KEEP this gear, rotating rod, and metal retaining ring (2) if you purchase a new sensor from a store. My guess is that the new sensor unit will not include these parts.
Top view of the sensor where wire leads connect. Clean if needed.
Bottom view.
I removed the three screws using a Phillips screwdriver to clean the interior components. Be very careful when removing these screws because black plastic top of the sensor has a bit of a spring-like tension hold to the metal sensor housing. Be sure to not lose the bearing shown (1). This magic BB probably controls the entire ECM J. Clean the sensor contacts (2) and rubber O-ring. Replace ring if needed, though this may be pre-formed and a pain to “fit” with a standard O-ring replacement.
Shown are the cleaned components.
To finish up I joined the top (plastic) component with the bottom (metal) component and tightened the three screws snug. No need to gorilla torque, remember this is plastic on metal! Just be sure to tighten evenly. Next, carefully replace the sensor unit into the opening on the transmission. You may have to jiggle it a bit to get the gear wheel to align with the other gear residing in the transmission itself. Hand thread the bolt, then tighten down with wrench. Next, slide the wire harness back onto the sensor and “feel” the click. Finally, connect the battery terminals if you took them off. Now get behind the wheel and start it up. Drive around and enjoy!
I have not had any problems whatsoever. No CEL or speedo/tach/odometer problems, even while driving it hard!
2000SolaraIL is offline   Reply With Quote
The Following 4 Users Say Thank You to 2000SolaraIL For This Useful Post:
ajkalian (06-18-2010), fenixus (06-18-2010), Maim Menu (06-18-2010), peshwa (06-18-2010)
Old 06-18-2010, 12:39 AM   #2 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
great work dude...vote for sticky!
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 06-18-2010, 12:46 AM   #3 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Second that vote!
Also, your solara engine bay, with the exception of your strut bar, IS gen 4 camry. I thought they just had the same engine...but they have the same everything!
Chris Crash is offline   Reply With Quote
Old 06-18-2010, 06:35 AM   #4 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Sticky that mother up in the DIY list.
If half of Camry owners would show up here like you to document stuff, we would never need to pay for garages anymore.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 06-18-2010, 08:07 AM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
best 1st post ever
^ and leaving it that way!
Old 06-18-2010, 08:46 AM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Thanks!
Just cleaning it... simple and not going to cost a lot of money.
That sensor is a coil, and the transmission is spinning the magnet around, just like the crank position sensor.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-18-2010, 04:41 PM   #7 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Nice write up!
Lets connect the dots: CEL ###
DTC P0720 Output Speed Sensor Circuit Malfunction (For Electronically Controlled Transaxle).
Also, I'd recommend you apply a dab of ATF to the o-ring before inserting it into the trans so it slides and does not tear the O-ring.
Might want to measure the two terminals for:
A) open, infinite ohms
B) short, zero ohms
C) Resistance from either lead to body = infinite ohms <unlikely unless catrostrphic failure
IIRC it doesn't list the actual ohms but similar sensors read 560 to 680 ohms, but don't quote me on this. The final check is by means of oscilloscope output expecting a square wave. This goes into another circuit for clean up before hitting the ECM.
Mechanically, the drive gear shouldn't have a bunch endplay or lateral (side to side) motion either. These would lead to an irregular output which could create a cel.
73sport is offline   Reply With Quote
Old 06-18-2010, 06:11 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
amazing 1st post !!
great job 2000SolaraIL.
feel free to post anything about your solara's engine or tranny in this section. camry gen4.5 is an exact same thing as solara 2000-2001 (i think gen1.5 it is) in terms of thing under hood
nice to see another Solara owner around here
