Timing marks on crank and cam pulleys 5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2010, 02:27 AM   #1 (permalink)
View GabrielG1786's Photo Gallery
3rd Generation Timing marks on crank and cam pulleys 5sfe
hey guys, i got a 5sfe from a 95 camry to put into my 93 camry. I wanted to make sure that the timing on it is correct, since the guy who sold me the engine said that he had it rebuilt. how are the marks on the pulleys suppose to line up?? or do i need to put the engine in the car and hook it up and crank it? its my first swap and i want to make sure everything works right and fires up once i put it in. thanks
GabrielG1786 is offline   Reply With Quote
Old 06-19-2010, 02:59 AM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
DIY: GEN3 Timing Belt + Waterpump + Oil Seal Change - Part 2
71Corolla is online now   Reply With Quote
Old 06-19-2010, 03:03 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Cam pulley: Hole in cam pulley aligned with notch on bearing cap. Refer to picture.
Crank pulley: Mark/notch on crank pulley aligned to "0" mark on timing belt cover.
1. Using a socket and wrench on the crank pulley bolt, turn the crank clockwise till the mark on crank pulley lines with the "0" mark on the timing belt cover.
2. Check the cam pulley. The hole in the pulley should be lined up with the notch on the bearing cap. Upper timing belt cover needs to be removed to check the cam pulley.
You may have to turn the crank 2 full revolutions (720 degrees) to get things to line up properly. The cam rotates at half the speed of the crank.
The Following User Says Thank You to 88 LE For This Useful Post:
GabrielG1786 (06-28-2010)
