94,camry le wagon reliability w/ 80k.? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2004, 11:59 PM   #1 (permalink)
View jamesmetairie's Photo Gallery
a friend wants to sell me a 94 camry wagon w/ 80k. it is V6,a/t,one owner. anyone out there can tell me if that,s a good year? do those V6,s have the sludge problem? does it have a timing belt or is it a chain? future mpg=-? average repair costs? any help would be appreciated. thanks,jim.
6&8.
jamesmetairie is offline   Reply With Quote
Old 03-29-2004, 09:25 AM   #2 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $231501
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
be very careful take off the valve cover and check for sludge ask and see if he replaced the timing belt, and if you do get it i highly sugest getting a volt meter and a oil pressure guage that way you can save the engine before any damage can be done. the oil pressure light comes on below 5psi by then you need a new engine you pressure should be no lower than 17to20psi at idle. but go for it just do what i said and you'll not have a single problem. uh is it 4cyl or 6? 3rd row seat?
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 03-29-2004, 09:45 AM   #3 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
Sludge was a problem with later 5SFE cars (that would be the four cylinder, and not the V6 jamesmetairie is looking at. If the car has been well cared for, with regualr oil changes, I think you're good to go.
As far as I know it uses a timing belt.
Now you mention it's a 94, there were two V-6's used that year- the 3VZ-FE, which was an evolution of the 2VZ found in earlier Camrys (dates back to '88ish) and from about '94 1/2 on the 1MZ-FE (V6 ppl am I right about the codes). Which one is it, can you find out?
A low-mile '94 that's one-owner sounds like a screamin' deal (80k is nothing on these). Good luck
Steve
'08 Camry LE 5-speed. Stock as a rock.
87Camry5Speed is offline   Reply With Quote
Old 03-29-2004, 09:55 AM   #4 (permalink)
View BigAirSkier1580's Photo Gallery
Check CV Joints. I've replaced mine at about 70k, and I've heard many others have as well.
BigAirSkier1580 is offline   Reply With Quote
