What are these throttle body hoses (with picture) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2010, 08:05 PM   #1 (permalink)
View coffee-3000's Photo Gallery
3rd Generation What are these throttle body hoses (with picture)
Does anyone know what these two hoses attached to the back on the throttle body are ? I highlighted them with a red dot on the photo.
This is a 96 V6 Camry with a 1mzfe engine.
Just curious.
No issues.
1996 V6 Camry 150K
coffee-3000 is offline   Reply With Quote
Old 06-20-2010, 08:32 PM   #2 (permalink)
View camry6's Photo Gallery
Just curious.
No issues.
Where's the pictures??
camry6 is offline   Reply With Quote
Old 06-20-2010, 08:34 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 06-20-2010, 08:49 PM   #4 (permalink)
3rd Generation
Sorry about that. I justed edited the original post and inserted the picture.
1996 V6 Camry 150K
Old 06-21-2010, 05:13 AM   #5 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Did you trace where the hoses went to? It would probably easier that way...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 06-21-2010, 08:52 AM   #6 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
power steering something something
^ and leaving it that way!
Old 06-21-2010, 11:49 AM   #7 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
I didn't look to be certain so don't quote me on this but one is PCV and the other loops back to the brake booster. it took the long road as IIRC.
What up?
73sport is offline   Reply With Quote
Old 06-21-2010, 01:38 PM   #8 (permalink)
No issues with the hoses. Just trying to make sense of them all.
I couldn't find these on any parts diagrams.
They don't appear to be running into the engine.
They appear to be running down the firewall to the front axle.
I'll look closer tonight.
Chronoti says power steering.
73sport says one might be pcv and the other might be brake related ( I think).
I'll keep this in mind.
Thanks again guys.
1996 V6 Camry 150K
Old 06-21-2010, 02:55 PM   #9 (permalink)
96 3MZ M/T
chronoti's Avatar
pcv is on the under side of the manifold, brake booster is on the backside on the aics plate.
the ps system uses a vacuum assisted system both hoses run in to a round silverish thing that runs down to the rack i believe it drives the high speed bypass
The Following User Says Thank You to chronoti For This Useful Post:
coffee-3000 (06-22-2010)
Old 06-21-2010, 03:04 PM   #10 (permalink)
V8'sRGone
73sport's Avatar
You're gonna make me look it up!
In the Gen 3 - 3.5 manual EG2.PDF pg 15, it shows (chronoti correct) upper hose from ACIS going to the brake booster via the firewall. It shows the lower hose near the ACIS going back to upper hose in the OP picture.
Page 27 looks to have something of two vaccum hoses going to the PS switch????
Disreguard my comments as IDK!
OP - your car electric or hydralic cooling fans?
The Following User Says Thank You to 73sport For This Useful Post:
Old 06-21-2010, 03:53 PM   #11 (permalink)
I just checked. I do see the two hoses both entering the silverish ( i.e. chrome ) looking thing along the firewall. This chrome fitting is at the top of a chrome pipe. The pipe continues down to the axle location. The pipe also has a hose that branches off of it. I googled the part number of this hose and its description is "high pressure side power steering hose".
Thanks again.
I found a diagram of the two hoses going to the silverish thing on page 27.
It's actually called the Air Control Valve Assembly.
The two hoses are both called "Air Hose #3".
They get the air from the throttle body to be used in the power steering.
1996 V6 Camry 150K
Old 06-22-2010, 10:39 AM   #12 (permalink)
V8'sRGone
73sport's Avatar
^^ Good work.
FWIW: I looked under my hood last night. Mine is not the same as that. In your original photo you have that CAP pluging a line, Mine has a three way vaccum switch connecting those lines together. Not sure what it does tho!
Old 06-22-2010, 11:10 AM   #13 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
if you have a hydraulic cooling system, then you will have those hoses
I never figured out why there are two of them since only one will suffice (I've been only running one since I installed my supercharger), and it's for the power steering idle up
HaHa
