It should be controled by one cable. Did you check to see if the cable is still hooked up to the airmix damper control arm? Maybe the cable isn't hooked up to the control switch any more. Did you pull the control panel and check? Is yer Camry made in Japan or the US?
Control cable part number: 55909-06020
From ToyotaPartSales.com
Mechanical Catalog
Item Number MSRP Core Price Price
5590906020 $11.35 $0.00 $8.18
Hvac - Controls - Dash control unit
Dash control unit, camry, all, w/o atc, cable 1997 - 2001
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
