92 gen 3 fluid help needed differential - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2010, 10:19 PM   #1 (permalink)
View jaswasup's Photo Gallery
3rd Generation 92 gen 3 fluid help needed differential
changed out my driverside CV Axle tofday and it puked fluid all over the driveway
Now - as it is a 5 spd manual - wher do I fill this back up and what type of fluid is required
Please help
Thx
jay
jaswasup is offline   Reply With Quote
Old 06-20-2010, 10:43 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
differential fill plug is on the back of differential (firewall side). there is tight access as you will have axles and exhaust pipe on the way from bottom. 3/8'' ratchet should fit in there.
you will need either 17mm socket or 10mm hex bit to open it up. hard access makes it impossible to use breaker bars or so, so get some PB blaster to break it free or you risk stripping it.
it takes same fluid type as the tranny, so any ATF will do (Castrol Import Multi-Vehicle Synthetic Blend, Mercon V, Dexron III, etc.).
Old 06-20-2010, 10:58 PM   #3 (permalink)
diff fluid
this is a standard tranny
- so are your references correct- I see your auto tranny post -
Will I find the plug easily
and I will loosen the fill one first as mentioned in other threads
I was surprised at how much fluid actuall came out
What will be the consequence of driving it whil low /out of diff fluid - how far would it take to acutally do damage ?
Old 06-20-2010, 11:03 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
idk man, i am referring to 5S-FE auto tranny. no idea about manual tranny.
my differential takes 1.7qts of ATF (drain & refill).
you cannot drive it at all with empty differential as you will damage things with no lubrication. same about very low level, don't drive it until you refill it.
Old 06-20-2010, 11:09 PM   #5 (permalink)
diff fluid specs?
ok so ----
I am in need of knowledge refereing to the kind of fluid to refill the lost fluid from changong a CV axle on my 92 4 cyl MANUAL transmission
When I pulled the axle out i lost a bunch of real nasty smelling fluid
Need some instruction on where to fill it and with what
Keeping in mind this is a MANUAL trans 4 cyl model
A REAL GAS MISER
Old 06-20-2010, 11:14 PM   #6 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Originally Posted by fenixus View Post
manual or auto tranny/diff take same fluid type bro. that is per my owner's manual.
So the differential is a separate unit like the auto box? 75W-90 for the transmission, Dextron for the differential?
71Corolla is online now   Reply With Quote
Old 06-20-2010, 11:16 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
do you have owner's manual for your car ?
mine states this for manual tranny (5s-fe), oil type: gear oil API GL-4 or GL-5, capacity 2.3qts, recommended viscosity SAE 75W-90. there is nothing about differential though, only something about clutch (fluid type SAE J1703 DOT3).
it's possible the differential shares the fluid with tranny then ? since they do not give the drain & refill capacity of differential, then maybe it's shared and you fill it through the dipstick together with tranny oil ?
have you checked the level of tranny fluid ? is it low now ? is there any fluid at all now ?
Old 06-20-2010, 11:17 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
disregard that, i clicked submit, before double-checking (read wrong page).
Old 06-20-2010, 11:17 PM   #9 (permalink)
71Corolla's Avatar
Ya I thought the manual just took gear oil that that's it. Look in the owners manual, that will tell you exactly what you need.
Old 06-20-2010, 11:18 PM   #10 (permalink)
71Corolla's Avatar
lol yea ninja edit there. Confused me for a bit.
Old 06-20-2010, 11:23 PM   #11 (permalink)
抵抗は無駄です
fenixus's Avatar
sorry i got confused myself for a moment. dang you were quick in quoting me on that LOL
Old 06-20-2010, 11:33 PM   #12 (permalink)
owners manual says !
In the manual it lists the manual transaxle fluid
multipurpose gear oil
75w90
is there a diffrential ? as it only states the differential under the auto transaxle listing
now i am confused
do i just need to top up my manual transmission or is there a differential ?
Old 06-20-2010, 11:42 PM   #13 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah, same in mine, that's why i asked you a few posts above if you have LOW or ANY fluid left in tranny now ?
Old 06-20-2010, 11:53 PM   #14 (permalink)
71Corolla's Avatar
No. Your wheels are locked solid, makes turning a real bummer.
Being serious, the diff is part of the whole unit, unlike the auto transmission where it is a separate unit with a separate drain/fill. That's my understanding anyway.
Old 06-20-2010, 11:54 PM   #15 (permalink)
manual trans
definatley low
Only problem is as it os a manual trans I do not have a dip stick
I understand the possibility of one being the same = trans/diff
However need to confirm it - as well - where the fill point is on the manual trans
