97 Camry LE Door Locks Gone Loco - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2010, 10:31 PM   #1 (permalink)
Banned
View Merryfrankster's Photo Gallery
4th Generation 97 Camry LE Door Locks Gone Loco
It's a 5S-FE with about 112,000 miles. No visible deterioration or rust anywhere. It is equipped with power locks. All the power locks seem to work ok. However, all the locks start to lock and unlock simultaneously on their own while driving. It seems to happen after the car gets hot from exposure to sunlight. No other electrical malfunctions. I've removed the door lock fuse as a temporary solution - however this means that the locks are all manual, a loss of functionality. Before I start randomly ripping and replacing stuff (master switch, passenger switch, integration relay behind driver kick panel, door lock module behind passenger kick panel, etc.) does anyone have any ideas on what I should focus on? Thank you for your help.
Merryfrankster is offline   Reply With Quote
Old 06-20-2010, 10:47 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Could it be something as simple as one of the lock/unlock switches is flaking out? Do you have a keyless remote?
71Corolla is online now   Reply With Quote
Old 06-20-2010, 11:02 PM   #3 (permalink)
View carpetguy00's Photo Gallery
I have a similar problem with my 97 LE. They unlock on their own. Never locks, only unlocks. I have only known it to happen when the key is in the ignition, tho I have only had it since feb. I have the dealer or factory installed rs3000. the alarm system functions correctly......
97 Camry LE 5SFE 135k
94 Corolla 1.6 @ 215K
97 F150 xlt v6 120k
92 Accord 4cyl 127k (totalled 8.4.11 by semi)
carpetguy00 is offline   Reply With Quote
Old 06-21-2010, 03:54 AM   #4 (permalink)
Banned
I don't know whether this car ever had a keyless remote, and I don't really know what to look for to determine that.
I intend to test the switches by disconnecting them one by one to see whether that changes anything.
Old 06-21-2010, 05:07 AM   #5 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Sounds like you have the dreaded frayed wiring in the driver's door...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
