Can't get the crank bolt off. The engine is stripped so I don't think I can turn it over. I've got a #14 wrench on one of the torque converter bolts and it's stopping the engine from turning over well but I've already cracked a #19 socket using my 1/2 inch ratchet with an extension bar on it and broke a 3/8" ratchet. Any suggestions from here????
Use an extension bar on it and have the bar propped against the ground. Then go turn the key and just kinda 'blip' the starter.
[QUOTE=Chris Crash;3236487]Use an extension bar on it and have the bar propped against the ground. Then go turn the key and just kinda 'blip' the starter.[/QUOT
I've read about that but everything is pulled apart including the main wiring harness to get at the cam seals. Does that matter? Will the car turn over? I guess I could always go out and try to start the car....
Probably not. Get a length of wire and touch the starter terminal to the positive side of the battery. That'll turn it over. Don't do it in gear, please.
Some engine crank bolts are reversed threaded, but not on the 5SFE that I know of. The bolt is torqued to 80 lb/ft, so unless there is corrosion it should take much more than taking off a wheel lug nut.
Besides the starter trick there are also:
1. thread an 8mm bolt in the pulley (there are two threaded holes). Use a pry bar between the socket and the 8mm bolt. The pulley should wedge against the pry bar and stop turning. However, the bolt is likely to bend first.
No rust on the car, it only has 220,000 KM. It's crazy how stuck this bolt is. I had to put the right engine mount back in as the whole engine was torquing by how much I was pulling on it. This really makes no sense. I'm not too worried about making/buying a pully holder as I've got a wrench on one of the converter bolts that is stopping the crank from turning.
Try the other alternative methods. If they don't work maybe get a 1/2" impact wrench. 3/8" won't work. 3/8" sockets are good for up to 80 lb/ft of torque, and sounds like that bolt is much more than that.
For really stubborn bolts, use a breaker bar and position it about 5 inches from a striking surface, preferably something immovable like the garage floor. Spike the starter and the breaker bar will get up some speed before it stops, shocking the bolt loose. I've never seen a bolt that could withstand the force, it will either come loose or break off (highly unlikely). Just beware, the torque is tremendous so stand back, and make sure the car is properly supported! Also make sure the bar is not going to crash into some cosmetic part of the car.
Or a high powered impact wrench will work great if you have one.
BTW, if the engine is not on its mounts, I could see why you can't get the bolt loose, the engine will twist too much I think.
I just had the one mount off on the passenger side but i put it back on once I saw the engine torquing. I'll try letting the ratchet work up some momentum as well.
Here's how I solved the problem. I made this from a floor flange and some pipe that you can get at Lowes or Home Depot. Once attached to the pulley, you can wedge the bar against the suspension, and get a big breaker bar and jump on it if necessary. The bolt will come loose. Be sure to check the spacing between the bolt holes. Seems it varies from model to model. The whole thread is here if you want to read about it in detail.
But the "bump start" method is the easiest way to get the bolt off. This Club was used to hold the pulley, for re-assembly to re-torque the bolt, since the specs are 130ft/lbs, and the motor will turn over at a little over 80 ft/lbs.
BTW, I'm 99.999% sure that the bolt is NOT a reverse thread.
