what to replace for engine oil leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2010, 04:54 PM   #1 (permalink)
rob
View rob's Photo Gallery
92 Camry, 3VZ. I've got the engine stripped apart fixing oil leaks. So far I've put in new cam seals and a distributer o-ring that were leaking bad, as well resealed the half moons on the heads. I'm going to replace the crank seal if I can get the bolt off. The car has a lot of oil under it, so much it's hard to tell where it is coming from. I'm worried I will not have replaced all the seals I should have to stop the leaks. Any advice on the obvious things I should replace other than what I already have? thanks.
rob is offline   Reply With Quote
Old 06-21-2010, 04:59 PM   #2 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
Front and rear mains
Oil pump gasket
Spark plug tube grommets
Valve cover gasket
All other gaskets required to reassemble the engine
Use RTV for the oil pan(s)
If I knew which engine, I could be more specific. You said cam seals (plural) so, 3VZ?
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 06-21-2010, 11:15 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
There's an o-ring sealing the oil filter mount. It's normally a bear to replace because the front exhaust downpipe blocks access to the bolts. Now would be a great time to replace it.
Edit: Here's a link to a thread with a pic showing where it is.
Link to thread
The p/n is 90301-68004; should cost about $8.
BMR is online now   Reply With Quote
