Headlamp aiming gauge '97 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2004, 01:19 AM   #1 (permalink)
View N4TECguy's Photo Gallery
I searched the forum and found a lot of good stuff about aiming the headlamps. However, nobody ever mentioned how exactly you can tell if your headlights are aimed correctly without using a wall. In my Accord, the headlamps have indicators that tell you when your aim is correct, for both horizontal and vertical. They're not exactly the most accurate but seem to work well for the most part. So my question is, does the 4th gen Camry also have these indicators? Or do I have to go and find a damn flat street with a wall at the end of it in hilly SF?
'03 Camry SE I4 AT - 102K
'02 Camry LE I4 AT - 135K SOLD
'97 Camry LE I4 auto - 188K SOLD
'04 Mazda6s V6 5MT - 65K
N4TECguy is offline   Reply With Quote
Old 03-29-2004, 01:34 AM   #2 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
Use your garage door, or find a parking garage.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 03-29-2004, 01:35 AM   #3 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
No, there aren't any indicators. The proper alignment can be found in a chilton manual, but roughly the angle is such that for every 25', the top of the beam must drop 1.2(?) inches.
BTW, if you'd like, flag me down and say "hi" since you're in the city. I'm always out and about on the weekends.
Time is never wasted when you're wasted all the time.
SKYravefever is offline   Reply With Quote
Old 03-29-2004, 07:45 PM   #4 (permalink)
Okay good measurements, but what are the beginning dimensions? Ex. at 25' away from a perpendicular surface, the "intense" part of the headlamp should be at x inches above the ground. Do you mean drop 1.2" from the middle of the headlamp?
