Differences in 5s blocks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2010, 11:52 PM   #1 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
Hey all, just wondering if anyone knew the differences between different gen 5S blocks. I heard/read that there was differences in water jacket locations between the older and newer blocks. Because someone is giving away a 5s but is a 93 and came out of a MR2. Does any one know if heads from any year 5s are interchangeable? IE 93 block 99 Head?
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is online now   Reply With Quote
Old 06-22-2010, 12:42 PM   #2 (permalink)
RHD is cool
camry_RHD's Avatar
View camry_RHD's Photo Gallery
try locate engine block number and see diffs?
camry_RHD is offline   Reply With Quote
Old 06-22-2010, 11:26 PM   #3 (permalink)
Creeps228's Avatar
huh and if i can where would that be?
MR2: 7A-GE
Old 06-22-2010, 11:44 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
http://en.wikipedia.org/wiki/Toyota_S_engine
Bore and Stroke are different. Just FYI.
'07 Honda Ruckus Big Bore
Old 06-23-2010, 12:01 AM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i dont see any diff in bore or stroke..... it both 5s's
i dont think you can swap the heads like that i can only say get the head gaskets and compare, but look at the 5s-ge threads those will explane more on the differences
^ and leaving it that way!
Old 06-24-2010, 12:58 AM   #6 (permalink)
Creeps228's Avatar
all 5s bore and stroke are the same i know that there is a difference between water jacket location because gen 2 3sgte heads and some 5s blocks match up perfectly...then toyota changed up the water jacket locations
MR2: 7A-GE
Old 06-24-2010, 10:59 AM   #7 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Any 5SFE cylinder heads bolt onto the 5sfe blocks and are interchangeable regardless of the water jacket locations and year.
If you're going to use a 5sfe head, use the 5S head gasket, if you're going to use a 3SGTE head, use a 3SGTE head gasket.
RichieRichJP is offline   Reply With Quote
The Following User Says Thank You to RichieRichJP For This Useful Post:
Creeps228 (06-24-2010)
Old 06-24-2010, 05:30 PM   #8 (permalink)
vL
92Camry5sp's Avatar
Gameroom cash: $219005
View 92Camry5sp's Photo Gallery
There are no difference in 5s block. i forgot who i heard it from, but the 98 camry 5s block was one of the best made. My coupe right now have a 98 camry 5s block with a 94 camry 5s head. I took it in for smog check, and it pass. Therefore, i believe there isnt anything different in the block.
92Camry5sp is offline   Reply With Quote
Old 06-24-2010, 06:58 PM   #9 (permalink)
Originally Posted by 92Camry5sp View Post
There are no difference in 5s block... Therefore, i believe there isnt anything different in the block.
Your assumptions are wrong.
Please refer to my 5sgte thread immediately.
Old 06-24-2010, 11:10 PM   #10 (permalink)
RHD is cool
camry_RHD's Avatar
Wink
you can swap a 5sfe from 99 in a 01 camry if you want but sometimes you need diff ecu due hp loss or win
Old 06-25-2010, 12:05 PM   #11 (permalink)
That doesn't make sense when the block is the same
Unless the stroke or CR is different, there shouldn't be any change in performance, especially if it's a straight OEM to OEM swap.
The electronics that would be of any effect on the block would be the knock sensor. This is probably the only thing that will have any effect on the ECU, which on these blocks, you either have one or not. Therefore you don't need another ECU.
