Screen to Protect Condenser/Radiator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2010, 08:25 PM   #1 (permalink)
2000 Avalon XLS Owner
Easywin's Avatar
View Easywin's Photo Gallery
The previous owner of my Avalon put a metal screen over the condenser to protect it from road debris. The screen was not like screen from a screen door, but more like a grid of 1/8" squares. It was made of stiff metal which I thought it was a good idea to protect the condenser, but it was also the source of the hole in my condenser and the reason for my wallet for becoming lighter.
I would like to know what others are using to guard their condenser/radiators from damage, without hindering airflow.
Stock 2000 Avalon XLS
Easywin is offline   Reply With Quote
Old 06-22-2010, 09:02 PM   #2 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
I molded 1/4" diamond aluminum mesh to fit into the lower grill.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is online now   Reply With Quote
The Following 2 Users Say Thank You to DxElite For This Useful Post:
Easywin (06-23-2010), JohnGD (06-23-2010)
Old 06-22-2010, 09:08 PM   #3 (permalink)
Justin
JJ9284's Avatar
View JJ9284's Photo Gallery
For the race car we use a screen in front of the radiator just like you did. keeps out small rocks and rubber from causing troubles. It works great
1995 Camry
JJ9284 is offline   Reply With Quote
Old 06-22-2010, 09:38 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I can't believe people actually install shields like that. You learn something knew everyday...
'07 Honda Ruckus Big Bore
Old 06-23-2010, 08:18 AM   #5 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
Gameroom cash: $391902
iTrader Score: 6 reviews
View Gothmog3VZ's Photo Gallery
*new
1993 Toyota Camry 3VZ 5-Speed
(Beige Beluga)
1989 Toyota MR2 3S-GTE 5-Speed (Din)
Need performance parts?
Shoot me a PM, I'll see what I can do
Gothmog3VZ is offline   Reply With Quote
Old 06-23-2010, 05:42 PM   #6 (permalink)
Easywin's Avatar
Where did you pick up the screen? How did you attach it?
Old 06-23-2010, 06:14 PM   #7 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
Yeah I'm interested in doing that for my '96.. I like how the mesh is forward instead of back, so how'd you attach it?
iovaykind is offline   Reply With Quote
Old 06-23-2010, 06:45 PM   #8 (permalink)
DxElite's Avatar
That was the main design decision, I didn't want to just put a flat sheet behind the bumper. Make it look more professional by making it flush to the face of the bumper.
Mesh was bought off of ebay, but if I were to buy more I would do more research and find a good place that sells custom sizes.
The ones I got from ebay were standard sizes and wasn't as long as I'd like.
I couldn't get it to go all the way to the bevel at the ends of the grill opening.
I molded the mesh into an angular " [ " shape and inserted it into the grill opening.
The top and bottom of the " [ " are long enough to stick out behind the bumper cover.
The grill opening has those vertical slates so the bottom and top of the mesh were cut so that it can slide back.
Using galvanized steel wire for rust prevention, at each vertical slate where the mesh was cut, I tied the mesh back together behind the vertical slates. This is done at the top and bottom.
The mesh is tied together at the center the two meshes.
As for the very edges where there's basically nothing to tie the mesh to, I drilled small holes to tie it down.
...Not sure if that's clear enough to understand, but I can try to explain it differently or post drawing/pictures if needed.
Old 06-23-2010, 07:13 PM   #9 (permalink)
iovaykind's Avatar
That actually makes a lot of sense I'll be hopping on that soon enough, thanks for the DIY.
Old 06-23-2010, 08:44 PM   #10 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
