Originally Posted by Raptor5150
so after alot of work i finally figured out whats been putting my car into safe mode...i replaced the knock sensors on both banks but i was still throwing a CEL and getting a code 55... i guess the wiring was melted or somthing on the right bank so it still wasent giving a signal...
very frustrating this safe mode is..but today i was driving with my AC on full blast on the body only setting..and normally when i drive for about 10 minutes ill throw a CEL but with the AC on...1 hour went by...no CEL o_O... just driving through town and stuff stopping and starting...and flooring it sometimes which normally makes me throw the CEL...
how does me having the AC on make my timing not retard to the maximum level (aka safe mode) ???
its soooo weird that this happened on 2 occasions its like a temporary fix untill i get new wires installed... im not complaining lol atleased i have the full power of my car when i want it...
any ideas?
Here's my opinion, take it for what it's worth......The problem doesn't lie with the knock sensors, as you have already found out, or the wiring leading to them. The ECU is overheating and giving you a false CEL. The computer is at fault and with your A/C set to max vent you are circulating enough cool air through the cabin, and the return air vent is underneath the dash, exactly the area where the ECU is located. This is supplying enough cooling to the ECU to keep it from throwing a CEL. Replace your ECU and it will be fine.
