Can't move my shifter out of P. Camry 94 LE 4 cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2010, 06:34 AM   #1 (permalink)
Gameroom cash: $120300
View johnjan's Photo Gallery
I cannot move my shifter out of Park. The car starts fine but the shifter knob that needs to be pressed to move the shifter out of P, is not depressing fully.
Anyone has any ideas how to fix this issue?
johnjan is offline   Reply With Quote
Old 06-23-2010, 06:55 AM   #2 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
That happened to me when the Brake fuse blew, so you could quickly check that.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is online now   Reply With Quote
Old 06-23-2010, 09:10 AM   #3 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i agree. i had the same problem turned out to be bad brake fuse. (10a)
just wondering if you can lift up(pick up) the shifter? ....
Old 06-23-2010, 09:26 AM   #4 (permalink)
Thanks.
Where is the brake fuse located?
Old 06-23-2010, 09:31 AM   #5 (permalink)
Gameroom cash: $127997
View jordan7831's Photo Gallery
I dont know how to fix it, but if you have to move the car you can override the shifter. Your manual will say to look for the raised cover on the shifter (above the ECT button) and while over riding the shifter with a screw driver, you can move the shifter into drive. However, if you try this be sure to firmly hold the brake down.
hope this helps, best of luck.
jordan7831 is offline   Reply With Quote
The Following User Says Thank You to jordan7831 For This Useful Post:
johnjan (06-23-2010)
Old 06-23-2010, 06:39 PM   #6 (permalink)
I found the brake fuse which is 15 A and is labelled as STOP fuse. This fuse is located in the dash on the left side of the steering. The fuse was blown, replaced it with a spare from the underhood fuse box. And it worked. Now I can shift the shifter out of Park easily.....
Thanks to all of you who suggested the solution...
Old 06-24-2010, 01:16 AM   #7 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Hmmm...that would be an interesting way of securing the vehicle from being stolen. Just pull the STOP fuse or wire in a toggle switch.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 06-24-2010, 02:36 AM   #8 (permalink)
View timefourfood's Photo Gallery
hehe rather than using The Club or the AutoLock, remove the fuse and put it in your wallet. thief can't drive your car away.
timefourfood is offline   Reply With Quote
Old 06-24-2010, 07:07 AM   #9 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
but you can override this by removing the small cap by the shifter and pressing that button to shift out of park. the only problem with this is the tail lights wont work, but the car can still easily be driven.
ghettosled is online now   Reply With Quote
Old 06-24-2010, 09:48 AM   #10 (permalink)
wont work as suggested by ghettosled. u can override it... but i think if u remove the efi (i think its called that) fuse car wouldn't start at all
Old 06-24-2010, 12:49 PM   #11 (permalink)
BamZipPow's Avatar
Wink
One could remove that override button.
Either way...how many car thieves would know the override button is there?
Nice suggestion on pulling the EFI fuse...but wouldn't that erase the learned fuel maps?
Old 06-24-2010, 12:56 PM   #12 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
All stored trouble / fault codes will be erased in the ECM.
FUel pump relay will not function -> No fuel pressure.
Many car thieves, including repo services know that.....
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
