Fans blows harder when I accelerate... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2010, 12:18 AM   #1 (permalink)
slcpunk's Avatar
View slcpunk's Photo Gallery
Fans blows harder when I accelerate, slower when I don't.
What in the world do you think this could be? Everything else runs perfect.
1997 Camry, 191k miles.
1997 Toyota 204k miles. Runs like a champ.
slcpunk is offline   Reply With Quote
Old 06-25-2010, 12:20 AM   #2 (permalink)
View Camry LE 94's Photo Gallery
What fans? The radiator fans?
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 06-25-2010, 12:24 AM   #3 (permalink)
95 Camry LEV6
Gameroom cash: $105900
View Drewfuspx's Photo Gallery
Only thing I can think of is that your alternator is sending less than ideal current at idle but when it spins up it's sending a lot more. I believe the normal range is between 12 and 14.4v. You can get a tester that plugs into your cigarette lighter to measure current I think.
At least... that's what I'd do.
Drewfuspx is offline   Reply With Quote
Old 06-25-2010, 12:35 AM   #4 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
I think he means the A/C? Unless he has a big hole in the firewall and can feel his radiator fans blowing.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 06-25-2010, 12:43 AM   #5 (permalink)
View matt621's Photo Gallery
it's normal. As you accelerate the alternator increases the voltage to the battery which boost the voltage to the fans which makes them run faster. You can easly see this by buying one of those cigarette lighter volt meters. At idle, you'll see 11-12V and as soon you get it gas it'll go to 13-14VYou might also have a loose or worn out belt... or bad alternator/regulater, etc.
matt621 is offline   Reply With Quote
Old 06-25-2010, 01:19 AM   #6 (permalink)
slcpunk's Avatar
Sorry, my interior fans. It does this regardless of what my fan setting is at.
I've never noticed this before that's why I asked. I put new belts on less than a year ago.
I suspected it may have something to do with the alternator. I have a volt meter, but not the kind that plugs into the cig lighter.
Old 06-25-2010, 01:38 AM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Autozone checks alternators and batteries for free. You should do both.
How long ago were they changed, if ever?
Old 06-25-2010, 05:05 AM   #8 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Does yer lights dim/brighten the same way in relationship to the RPMs?
How good are those battery terminals? Any corrosion/acid build up? How good are yer battery cables? How about yer grounds? Snap a few piccies of the engine bay and post them up...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 06-25-2010, 07:10 AM   #9 (permalink)
PortugalFocus's Avatar
Gameroom cash: $124395
View PortugalFocus's Photo Gallery
My 00 does the same thing. It's been normal for me since the day I got my Camry. It's just a voltage drop as everyone is saying. I never really notice it unless I have the blower speed set to 4.
PortugalFocus is offline   Reply With Quote
Old 06-25-2010, 09:10 AM   #10 (permalink)
bawazir_chicago's Avatar
View bawazir_chicago's Photo Gallery
i hear my fan blowing
It's hard to be humble when you're from Chicago.
link:http://www.cardomain.com/ride/3820102
bawazir_chicago is offline   Reply With Quote
Old 06-25-2010, 09:36 AM   #11 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Normal.
Alternator output is proportional to rotation speed.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-25-2010, 10:55 AM   #12 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Sounds like the definition of "normal" is up for grabs here.
IMO normal ranks in the "I hardly notice" catagory.
OP sounds like, it used to be OK and now its not normal and it is noticed!
List of all true:
Nominal battery voltage everything off: 12.4v
Idle voltage everything off: 13.0 -13.5
High idle voltage nominal: 13.8v +
A loose belt could cause alternator output to drop.
A bad connection, gound, battery, could cause battery output to drop.
A bad alternator could cause the voltage to be erratic.
The fan motor, switch, resistor block could isolate everything to the blower circuit itself.
Measure the battery voltage in all of the conditions above. If the voltages are good and lights do not dim or noticeably change output with engine speed, the fault could be something like the resistor block to the fan motor or the fan motor itself.
How doe the fan behave on High?
73sport is offline   Reply With Quote
The Following User Says Thank You to 73sport For This Useful Post:
peshwa (06-25-2010)
Old 06-25-2010, 05:11 PM   #13 (permalink)
slcpunk's Avatar
Yes.
I'll go to the Zone today and see what they say. I changed the battery last year. It's ALWAYS had horrible problems with build up and I'm constantly cleaning the terminals.
Alternator has never been changed in the ten years I've owned the car.
Fan is normal on high, only thing that I notice is in original post.
Old 06-25-2010, 06:02 PM   #14 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
keep us posted with autozone testing results on the battery and alternator, it might get interesting.
mine was doing pretty much same thing with old battery. with new one i hardly notice the fans blowing harder at high rpm vs idle, but if i was anal i would say yeah there is always a difference and i think it's kind of normal per toyota normal operating ranges.
Old 06-25-2010, 06:39 PM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992475
View MR2Jedi's Photo Gallery
List of all true:
Ditto that. Except voltage should be closer to 14.2 volts @ idle
The Jedi Speeder at CarDomain
