Originally Posted by 71Corolla
I believe it goes like this for the distributor:
6/1991 - 7/1993
8/1993 - 7/1995
8/1995 - 7/1996
Someone correct me if wrong, but I believe the answer to your question is no.
edit - to clarify, it's not impossible to do this, but would it be worth it? BTW, I don't see how a change to the ignition setup is going to do much for a smooth idle, Toyota added balance shafts later on to address the problem, I doubt a slightly different spark system will do a whole lot. I wonder if anyone has done this?
I also did the dog bone mod, I didn't see much if any improvement. The engine mounts, you should be able to find them online in Canada for about $110 each for the front and back. (probably not OEM)
Thank you for your clear answer, the Wikipedia did not mention about the added balance shaft, now that I know I think I won't try it.
With the age of the car, not sure if the total cost of replacing the engine mount is justified, I might let it stay this way, the vibration aren't mind blowing anyway, besides, I read some owner on here saying even after replacing the mounts, it still vibrates.
