As stated, when the CAT has to burn a bunch of RAW fuel because the engine passed it through w/out burning it, the cat runs hotter and can plug.
From what I've seen these things can run pretty bad for a LONG time before the CEL gets lit. Couple that with running bad gas for exteded times and the CAT takes a serious beating.
Sounds like you have ignition issues (no sparky to the plug) and it likely played a role in the cats failure.
A plugged cat won;t allow the car to make any power. It may idle fine, but won;t accellerate if being choked by a restricted exhaust. Both items need fixed. Try unscrewing the rear O2 sensor and see if it revs up better.
Edit: sounds like you need new coils!
Watch is run in the dark and/or spray the coils with a fine mist of water and see if it makes it run worse. You can also grab the coils with you hand while running. If its bad, you'll know it. < not advised, but it works! lol
