Long shot but has anyone who has completed a 5spd swap on the 1mz found a solution to the P1780 neutral safety switch code? Finished my swap last year but still have this code and won't be able to pass NYS inspection. If anyone has a solution please chime in thanks!
^ Volk Racing CE28s 19x8.5/8 for sale
quote from jon's transmission swap webpage:
the park/neutral switch wire must be cut at the ecu to prevent a CEL. its the smaller of the black with white stripe wires on the bottom plug of the ECU (pin 13 or 14, wichever is smaller).
Connect the black wire to the black with white stripe wire. This makes the ECU think the car is in park or neutral and allows the starter to operate. They should be connected to the clutch start switch, but this can be easier accomplished by accessing the wire under the dash.
i'm still learning on this so this is the best i can come up with!
tru! and dont say gen 4 ecu because that will give the issue of the missing vsv by the fuel tank. and an issue with the maf sensor
i think with it hooked to the clutch might work better because the signal wount constantly be there but if you sit on the clutch too long it will throw the cel.
gonna have to bit the bullet and get a $50 rpm switch or a piggy back that can switch it
^ and leaving it that way!
yes but you get the issue that the start safety switch is closed but it not picking up it being in park or neutral.
so if you dont need to check if your reverse lights work disconnect your reverse switch and then close the wire to neutral just for the test
also you cant leave the wire in neutral because it will throw a code if you put it in reverse ........ now i'm thinking dpdt switch where when thrown in reverse it will open the start and neutral switch ....... gonna take a bit of work
Ok you mean a mechanical switch that would open the neutral safety when in reverse... Could an electronic switch connected to the reverse sensor work? Using a relay on the sw input
Is this issue only occurring on the 96 ecu's? I don't recall ratko having any issues with this code. However eye8pussies has the same code what the hell!
