A/C controls in dash removal question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2010, 01:06 PM   #1 (permalink)
92 Camry 5S-FE
LittleWhiteBubble's Avatar
Gameroom cash: $115750
View LittleWhiteBubble's Photo Gallery
I just replaced my instrument cluster lights earlier this week. I would like to get to the bulbs behind the climate controls in the center of the dash to remove the green covers and paint them blue as well. I searched the other lighting threads but didn't see anything on how to remove the ac control area. My ac doesnt work, but the blowers and heat still do so I don't want to break any of the controls. Someone mentioned something about taking out the glove box to get back there. Is that correct? And does anybody have tips on how to make this job easy as possible?
Thanks guys
LittleWhiteBubble is offline   Reply With Quote
Old 06-25-2010, 02:27 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
remove the same trim you did for your cluster, and you should see 4(?) screws around the controls remove those should pull out a bit, disconnect the wires at this point you (and if you have not the xle push button) you should only have the inside outside wire left but you can remove the bulbs at this point
^ and leaving it that way!
Old 06-27-2010, 07:14 PM   #3 (permalink)
92 Camry 5S-FE
Thanks, you were right, it pulled out just enough to get the bulbs out.
Old 06-27-2010, 08:28 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Seeing the issue is resolved, I'm going to hijack this thread rather than create a new one. Is it possible to install the push button HVAC controls from a V6 into my car which is the 4 cylinder mechanical style? And by possible I mean reasonable without replacing dozens of parts.
71Corolla is online now   Reply With Quote
Old 06-27-2010, 10:38 PM   #5 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
No. The push button system requires small motors which are buried in the dash. You'd have to disassemble the entire dash of both cars to do the swap. I looked into this years ago. The work involved wouldn't be worth it. I'm fine with my rotary controls.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
The Following User Says Thank You to uibalnme For This Useful Post:
71Corolla (06-27-2010)
Old 06-27-2010, 10:52 PM   #6 (permalink)
71Corolla's Avatar
lol I'm fine with them too if I have to rip the whole interior apart to do the swap. Thanks for the info.
Sucks that Toyota went cheap on the LE, my 87 LE has nice push button controls dammit, and an nice temperature slider. I like buttons and sliding things.
