Clean EGR valve without removal? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2010, 04:45 PM   #1 (permalink)
View camrybartockus's Photo Gallery
Can someone clarify, to clean the egr valve, can you do it without removing bolt on head? Eg. DIY : EGR Valve removal . There it is taken right out. Can I simply remove the hose and spray seafoam in it? My car is a 94, will the sea foam kill it ot just run through it? Can I just use carb cleaner btw?
Thanks so much.
camrybartockus is offline   Reply With Quote
Old 06-25-2010, 05:56 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
i believe you really have to unbolt it from head if you want to get it done right. if it's clogged with carbon then majority of it will sit in the head opening and that bottom pipe.
