Wiring for 1992 Camry LE V6 with 3VZ-FE engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2010, 08:29 PM   #1 (permalink)
View hotspur's Photo Gallery
3rd Generation Wiring for 1992 Camry LE V6 with 3VZ-FE engine
Is there somewhere from where may I download wiring diagrams for my car free:
Specifically at the moment, I need to know the physical routing, coloring, etc of the wire(s) that run(s) from ground to pin number 4 of male connector on the harness to the Electronic Control Unit (ECU) for the cooling fan.
Currently, I'm measuring 29 kΩ for the resistance between ground and pin number 4 of the male connector on the harness to the ECU for the cooling fan, when I believe it should be close to 0 Ω instead.
hotspur is offline   Reply With Quote
Old 06-25-2010, 11:26 PM   #2 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
i have a color coded wiring diagram for the es300/3vz i could email to you. helped me out a ton.
rusty9 is offline   Reply With Quote
The Following User Says Thank You to rusty9 For This Useful Post:
hotspur (06-25-2010)
Old 06-25-2010, 11:42 PM   #3 (permalink)
3rd Generation Pleaase do email the wiring diagram.
Hi
many thanks.
Please do email the wiring diagram to me. I'll start from there.
I'm new to this, can you send that to me as an attachment when you Private Message (PM) me after clicking on my user name?
